Could I get some dimensional info please?
I’ve got an S63 Coupe and I’d like to do some mods. I’m going to fashion the 4 dr vents to work on my car. Could someone tell me is the center outboard vents are smaller than the center inboard vents. I do know the outboard vents are larger than the centers. Thanks in advance
NO, the plan is to remove the bulb from the OEM vent tube and replace them with the new version. Then I’ll place the entire assembly back into the original hole.
Is it easier to reuse the old parts except the bulbs? Just trying to figure out the actual problem in ordering parts.
That makes a difference. Have you already figured out that the new "bulb" fits to the old enclosure? Are these new bulbs available separately as some Chinese copy parts? If using OEM parts, it would be cheaper to purchase the side vents as such instead of purchasing multiple centre vents and using their parts on the sides.
Diesel Benz (02-08-2022)
