The gear shows D1-D7 rather than D.
I have the car, S550 2016 RWD, and drove it for almost 100k km. It was always displayed on D unless I press the paddle but now it just drives from D1-D7 depending on the gear and I can’t seem to get out of this back to D as always. Gear seems fine, shifts smoothly. What may the problem be?
2019 S560, 2022 Audi S8
Even between start/stop cycles? If it is during a daily drive and I've intervened the shifting by using my paddle shifters which I do a lot, I sometimes push down on the gear stalk while going down the highway to get it back into D. OR I press and hold the + paddle for about 2-3 seconds and it defaults back to D.
That is what mine always shows, the D and Gear, ti switches to M and gear when I use paddles. I cannot see what the full error message is on your screen so not sure if that ahs anything to do with this or not.
Received 2,704 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
It probably says Radar Sensors dirty but as to answer OP's question, it shouldn't change unless a TCU update was performed.
C Swenson (07-15-2022)
