Stock Ride Height
Subscribe
Aug 15, 2022 | 09:09 AM
Hello All! I'm brand new to this forum, having picked up a 2015 S550 4-matic a few weeks ago.
I'm the 4th owner of the car and one thing I can't get past is the height at which the car is sitting when in the lower suspension setting. There is zero gap between the fenders and front tires.
I attached four photos here to give a visual of what the car looks like in both suspension settings. For reference, those are stock 19" AMG wheels with correctly sized tires.
Can anyone provide some information on what the stock "low" and "high" heights should be? What I could look for to determine how the car was lowered? Seems that software changes is one option and springs are the second... And perhaps what my best course of action would be to return the car to its stock suspension settings?
Thank you all in advance! Hope to be able to post up some more pictures soon in the picture thread.
Full view - Suspension in the high setting
Full view - Suspension in the low setting
Front Wheel - High Suspension Setting
Front Wheel - Low Suspension Setting
Reply 0
Aug 15, 2022 | 12:28 PM
My guess would be someone put lowering links on all 4 corners. This can be pretty easily resolved with a set of factory links. Either that or there is a SW module somewhere that is causing this, typically found at the OBD port. It is definitely not set at stock ride heights though.
Wheels have also been painted. Hopefully they used plastidip product that can be peeled off if you are not a fan of the painted wheel look.
Reply 1
Aug 15, 2022 | 06:56 PM
Your car is most definitely lowered. One of the two aforementioned methods is my bet.
Cyrus
Reply 1
Aug 15, 2022 | 08:53 PM
Quote: Your car is most definitely lowered. One of the two aforementioned methods is my bet.
Cyrus
Nothing in the OBD2 port. First available appointment is 3 weeks out at the dealership, so I'll find some time to get under the car and see what I can find in the coming days.
Thaks guys.
Reply 0
Aug 15, 2022 | 09:13 PM
You could have a LoMo module installed, or custom airmatic settings/value via STAR, but most likely you have custom lowering links on your suspension. I won't be surprised if that car rides much better once your get rid of them!
Reply 0
Aug 15, 2022 | 11:33 PM
My guess is that someone lowered the air suspension and never brought it back to stock. From what I hear air suspension is fairly easy to deal with and almost any mechanic can do this. Call around and see who has experience. I wouldn't take it to the dealership because not only are they expensive but they might void warranty (if you have any). Don't ride with it lowered as it will wear the inside of your tires pretty fast.
Reply 0
Aug 16, 2022 | 10:43 AM
Quote: I won't be surprised if that car rides much better once your get rid of them!
Yeah, first ride was nice, but coming from a 2003 S500 it was certainly stiffer. I expect a nice improvement once we're back to normal.
Reply 0
Aug 17, 2022 | 03:20 AM
Your car looks very cool when it's sitting but If I were you I would also try to get back to its original settings as well
Happy Driving
Reply 0
Aug 18, 2022 | 11:57 AM
Quote: Your car looks very cool when it's sitting but If I were you I would also try to get back to its original settings as well
Happy Driving
Same feelings! It looks great sitting, but I'd rather have the full suspension available wy n moving. Hahah
Reply 0
Subscribe
Currently Active Users (1)
