S-Class (W222) 2014-2020
2020 S560 4Matic Engine turned off entering garage
Old Nov 28, 2022 | 03:45 PM
zitsky's Avatar
2020 S560 4Matic
I swear I’m not making this up. I enter the garage get close to something in front but not all the way. Car shuts off for 15 seconds. Then turns back on. It was on COMFORT mode. Haven’t seen it happen in three months of ownership. 15 minutes before I opened the door with engine running and closed it.
Old Nov 28, 2022 | 06:57 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
Sounds like the engine start/stop...
Old Nov 28, 2022 | 07:13 PM
zitsky's Avatar
2020 S560 4Matic
Do you mean ECO Mode?
Old Nov 28, 2022 | 07:16 PM
SW20S's Avatar
2024 S580
No, engine stop/start. Unless you turn it off it will turn the engine off when you're idling and start it back up again when you put your foot on the gas, or when it needs to in order to run the alternator. Have you noticed at red lights that the engine shuts off and comes back on like a hybrid?
Old Nov 28, 2022 | 07:43 PM
zitsky's Avatar
2020 S560 4Matic
It was more obvious on the CLS *loaner* I just had. On the S560 I do notice a shudder. I will watch the tachometer on the S class.
Old Nov 28, 2022 | 09:46 PM
seamus2154's Avatar
2016 S550 sport, 2018 GLC300, M3, Zo7, 2021 Sierra Denali
I have had that happen parking and pulling in garage if close to a stop. Its the start/ stop.
Old Nov 28, 2022 | 11:00 PM
2012 merc amg's Avatar
2018 S560
Best off to turn the eco switch off whenever you get in the car and start it, the eco mode start/stop and engine going into 4 cylinder mode is not good for the engine long term.
Old Nov 28, 2022 | 11:04 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
You might not have noticed start/stop before if your battery is below spec. On my car, this function only worked after a long highway trip when the battery reached enough of a charge for the engine to shut off. Since I replaced the big battery a couple months ago, it stops almost every time now. And it restarts much more gently. With the old, weak battery you could feel the engine shake a little as it came back on.
I'm curious how much benefit this really provides, I haven't noticed any thrilling increase in gas mileage.
Old Nov 28, 2022 | 11:45 PM
SW20S's Avatar
2024 S580
I had mine coded off
Old Nov 29, 2022 | 12:15 AM
C Swenson's Avatar
2015 S550 4Matic, 2014 ML550
Yes, zitsky, ECO mode.
"ECO Start/Stop Technology from Mercedes-Benz works to save fuel and reduce emissions by shutting off your engine when you don't need it."
Or even when you do need it.
Old Nov 29, 2022 | 07:22 AM
seamus2154's Avatar
Exactly! I had just replaced my aux battery and have been using a battery tender when not in use. Well everytime I get in the car with a full charge the start/ stop is kicking in all the time now! Prior with no battery tender and sitting for a week at a time, battery was never at full capacity or the level for start/ stop. So my good maintenance has bit me in the ***. LOL
Old Nov 29, 2022 | 05:34 PM
Mitch Alsup's Avatar
Top Answer: 1
S600
Do you know where to get a new battery that does not deliver a full charge--just so that damnable start/stop function stays off............
Old Nov 29, 2022 | 05:48 PM
seamus2154's Avatar
Unless your a daily driver or just came back from a roadtrip, the battery is almost never fully charged. My S is a second car and can sit from 1-2 weeks and sometimes longer. When I start using it, the start/stop never kicks in. But after highway use and using daily, or a road-trip she gets fully charged and that start/ stop then kicks in at each stop light. This time I know I was leaving it for a month, so I put a battery tender on it. Took it out today---full charge right from the get go, and start stop is working well.....and driving me nuts--- till I hit the button.
Old Nov 29, 2022 | 06:08 PM
Your werkshop can do something in xentry to see the charge level and condition of the starting battery. Mine was low and over six years old, so I replaced it just to be on the safe side (might have kept working for another year for all I know).
My start/stop kicks in all the time now since I replaced the battery, including when the car hasn't been driven for a week. I also did my aux battery over the summer as well, and I believe the condition of both batteries is an input to the start/stop.
We're on our third hybrid daily driver, so very accustomed to stop/start from those cars. Honda was especially clever and has a dual A/C compressor that runs on either the belt or an internal electric motor (or both for Max). That keeps the A/C going when the engine shuts down at a light, a darn nice thing on a 100 deg summer afternoon. I think Mercedes' newer 48 volt systems accomplish the same thing by running the water pump and compressor solely on electricity and thus, continuing the A/C when the engine's off.
