S-Class (W222) 2014-2020
RUN FLATS VS STANDARD
Old Dec 26, 2022 | 10:13 AM
potown andy's Avatar
2019 S 560 AWD
With all the chatter about run flats, here is my question....for those who have switched to standard tires, what is the difference in performance and what benefits result from the change. Also, how do you handle the lack of a spare? Thanks.
Old Dec 26, 2022 | 10:55 AM
vinflouen's Avatar
2019 W222 S560 4Matic/2025 Yukon Denali
I ditched the pirellis and went with Micheline pilots sports.
I kept 1 run flat on the rim and put it in the truck, along with my compressor, jack and tire repair kit.
The ride is much quieter and much better. Much less hydroplane with non run flats.
No Way I'd drive around with no spare and a way to change it on the fly.
I dont keep much in my trunk so no big deal for me.
Old Dec 26, 2022 | 11:56 AM
Jud Chapin's Avatar
'16 S550 Coupe, '11 Lexus LS460, '02 CL500 (SOLD)
Been driving since 1959 and have yet to need the spare. Maybe I'm just lucky.
Old Dec 26, 2022 | 12:25 PM
as.thompson's Avatar
Veteran: Air Force
S550C4, Porsche Cayenne
I too have been driving that long (got my license in '57) and I also can't recall ever needing a spare tire. I've had my share of slow leaks from nails, etc. but not requiring the use of a spare tire. When I got my '16 S550 Coupe it came with run-flats and no spare. Initially I was concerned about that but then realized that my driving experience really hadn't required a spare. And BTW I carry a pump and a sealer kit just in case I get a puncture.
As far as noise, to me they (Michelin Pilot Sport 4) seem to be only slightly noisier than the identical non-run-flats Michelins on my wife's SL.
Old Dec 26, 2022 | 12:29 PM
Jud Chapin's Avatar
W hen my run flats wear out on my S550 coupe, I was planning on replacing with normal tires because off the noise.
Old Dec 26, 2022 | 01:25 PM
Veteran: Air Force
I think that some of the newer run-flats are quieter than earlier versions. I know that the Michelins I now have are quieter than the Goodyears the car came with.
Old Dec 26, 2022 | 02:22 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
This has been answered many many times. The non run flats ride a little softer...thats the benefit. Dealing with lack of spare, I have an inflator and fix a flat kit.
Old Dec 26, 2022 | 03:11 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
As said the non run flat will ride Softer and will offer more grip.
Personally I just have the MB kit of sealant and compressor plus a set of plugs. I have never used the sealant as I prefer the plugs.
I did have 1 tire with side wall damage once that was not fixable with either but that car had a collapsible spare, in the end its how much of a problem would it be in the remote scenario that you have an un fixable flat.
Old Dec 26, 2022 | 03:37 PM
Donnymac's Avatar
63 Falcon vert
Basic comparison:
RF has a short rigid sidewall that when flat is capable of supporting the car for “50 mi at 50 mph per advertisement”. The rigid side wall improves high speed steering control but but accents any road surface condition change at any speed. That’s the RF basics.
NRF does none of the above. The tall side wall, when flat supports nothing. However, when properly inflated will give a mush ride compared to a RF ride.
The tread type and speed rating can also modify much of the above. As to flats, city vs hwy environments plus your driving needs should dictate the RF vs NRF choice.
Old Dec 26, 2022 | 04:00 PM
Veteran: Air Force
Originally Posted by VII
As said the non run flat will ride Softer and will offer more grip.​​​​​​
I haven't experienced non-run-flats offering more grip. The grip in my Michelin RF and NRF are about the same as best I can tell in two different cars. The rubber compund and the tread design seems to have more effect on the grip than the sidewall stiffness.
Old Dec 26, 2022 | 05:43 PM
braunfels's Avatar
S550
I have been pleasantly surprised by the 20 inch Pirelli run flats that came with my 2019 S560 that I purchased used 2 years ago. They seem to be just fine with the way they handle and I don't notice any road noise. Before this car, I owned a 2017 BMW 750i that also had 20 inch Pirelli run flats and I did not like them at all so I switched them for Michelin pilot sports and they were much better. So, maybe the car and/or the year of the tires makes a difference....but right now I'm going to stay with the run flats.
Old Dec 26, 2022 | 09:55 PM
Fred2's Avatar
Sprinter, agate grey sports car, e350 Wagon, S
I have noticed that runflats tend to skip sideways if you hit a sharp bump or crack in pavement while cornering.
The non runflats track better over the same piece of road.
Old Dec 26, 2022 | 11:20 PM
Donnymac's Avatar
63 Falcon vert
Yes RF hate rough road surface. NRF don’t care.
Old Dec 27, 2022 | 06:36 PM
Donnymac's Avatar
63 Falcon vert
Staggered now? Swap to staggered NRF? Use OEM wheels with taller NRF tire? Questions…
I have thought about the same.
Old Dec 27, 2022 | 07:02 PM
Veteran: Air Force
Just be aware that if you switch to a different size, i.e. "taller" as you said, you could throw off your speedometer and other suspension systems, especially if you have 4 Matic.
Old Dec 27, 2022 | 10:43 PM
aeggroup's Avatar
2025 Range Rover, 2022 BMW M850 , 2017 MB E400 Coupe
That's not true. The rolling diameter should be the same or no more than 2.5 - 3 %. For example 245/40/20 front and 275/35/20 rear or AMG size 255/40/20 front and 285/35/20 rear.
Old Dec 27, 2022 | 11:50 PM
Veteran: Air Force
The word "taller" indicates more than keeping the same diameter. By making the side wall "taller" using the same wheel you are increasing the diameter and it will have an effect. A "taller" sidewall will not have the same rolling diameter unless you change the wheels to a smaller diameter wheel.
Old Dec 28, 2022 | 04:19 PM
MBS63AMG's Avatar
2019 S560, 2022 Audi S8
Just make sure you put identical type tires all the way around on all four wheels or the geometric configuration of an odd-ball tire will cause damage to the other three. I learned this the hard way.
Old Dec 29, 2022 | 09:55 PM
Joshua's Avatar
If I may ask - what was your strategy for a spare ?
For context - I have a 2019 S560 W222. I have staggered rims - Front 245/49 R20. Rear 275/35 R20. If I wanted to mitigate the risk of needing a spare, would I not have to keep two spares for my staggered front and rear sizes ?
Also I was told by my local tyre shop (Melbourne Australia) that he would get me Michelin Pilot Sport 4S non-runflats and to just get a compressor to pump up enough to get me to a tyre repair shop iI get a flat. Not to bother with the Tyre Goo as it woukd render the tyre unrepairable and desyrop the TPMS sensors which (in australia) is greater than the cost of a new tyre.
michelin pilot sport 4s = $ AUD 560 per tyre fitted.
Old Dec 29, 2022 | 11:10 PM
SW20S's Avatar
2024 S580
No, your front and rear tires are very close in diameter, and one spare will work on both. I agree with skipping the tire goo if the tire will hold air.
Old Dec 29, 2022 | 11:30 PM
Joshua's Avatar
Thank you. that is good to know.
Old Dec 30, 2022 | 06:17 AM
DABRONX's Avatar
E55
Runflats were an idea to save mfg's money by eliminating spare tires and associated items. There is zero benefit to a consumer to have them as read the label you cant drive over a certain speed for a certain time. They do go flat and can blow out like a regular tire so all they do is buy you a mile or two to get off teh road quicker otherwise what is teh benefit? You destroy the tire when it goes flat and drive on it? You can damage your rim as the tire is flat. The ride quality is greatly deminished and one ride after the switch will confirm that. For all of that you get to pay $150 more a tire for them.
Switch and get AAA. Your S will never have drove so nice after. I will say one thing about mine is they seam to have lasted way to long although the demise came at 75 and a nasty blow out which made me a convert for life.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
