S-Class (W222) 2014-2020
Using Xentry to smooth 9G transmission
Old Jan 12, 2023 | 10:24 AM
vinflouen's Avatar
2019 W222 S560 4Matic/2025 Yukon Denali
I recently did a 4 wheel drive service on my 222.
​​After the trans oil change it was still shifting very clunky on 4-5 and 3-2.
I reset the trans in Xentry, and man I have to say, it's butter smooth.
Just a PSA.
Old Jan 12, 2023 | 11:48 AM
MB221's Avatar
W222 400D 4-matic
My dealer did just the oposite. Didnt reset those values after an gearbox-oilchange. When i got the car back it shifted even worse than before Their answer was it wasnt alowed by MB here in Holland. Sure..
Went to a indy wich told me thats BS and even manditory! He performed the "reset" and since then it started shifting better every day. Day after day. Now after some 40k miles it shifts like new.
Old Jan 12, 2023 | 12:27 PM
Diesel Benz's Avatar
Instead of the simple reset, you should run the adaptation tasks for each gear change. A lazy reset is not much better than no reset at all. Most likely the transmission adapts slowly to the same point in either case. Proper adaptation is just time consuming which is probably why the indy did not suggest that any more than the dealer.
Old Jan 12, 2023 | 01:39 PM
konigstiger's Avatar
'71 Pinto
Indeed!
Old Jan 12, 2023 | 02:19 PM
vinflouen's Avatar
Time consuming for sure, but worth it
Old Jan 12, 2023 | 02:49 PM
badq45t's Avatar
2016 S550e, 2005 Nissan Xterra 4x4, 1984 300ZX
How did you get access to Xentry?
Old Jan 13, 2023 | 09:36 PM
danmiles68's Avatar
2019 S560 4Matic
Look up BenzNinja, he can assist with this.
Old Jan 14, 2023 | 12:39 AM
S_W222's Avatar
Current/Last 5-years:GLS;G70;Alpina B8;X7;Accord. Sold:X7,TeslaS;S560;S550,X5;530e;L.Navigator;LS460
Just a PSA.
The reason I sold my W222 and switched to BMW recently is exactly this reason. Mercedes has lost a lot of my respect due to their jerky transmissions in the last 10 years. It is a shame that they still could not dial in a perfect smooth transmission. BMW transmissions are 10 levels above W222’s transmission. Even though I am on the market again shopping for a W222 once again, but I am still super concerned because I had a very bad experience with my previous W222 and took for ever to fix it but still not as near as good BMW feeling. I think it is hit or miss. I know not every car like that, but this seems to be a common and and well documented problem. Probably the only solution is to just design the 7G or 9G transmission from scratch instead of trying to update it again and again and again. It’s a shame.
Old Jan 14, 2023 | 10:51 AM
W205C43PFL's Avatar
Did they performed the steps mentioned in this thread: https://mbworld.org/forums/s-class-w...ting-w222.html
Old Jan 14, 2023 | 11:58 AM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
How many labor hours to do this adaptation process? Nice to make the trans work better, but at what cost?
Old Jan 14, 2023 | 12:01 PM
W205C43PFL's Avatar
Countless but that is the only way to make it as smooth as possible.
Old Jan 14, 2023 | 02:38 PM
'71 Pinto
Bulletin 722.9, screenshot 725: https://mbworld.org/forums/s-class-w...ml#post7961182
File Type: pdf
Old Jan 14, 2023 | 02:44 PM
S_W222's Avatar
Did you realize that I am actually the same person who posted that originally :P lol. That is my thread/post. So, of course yes. It made it better (smoother). But still my complain overall is that even after it’s fixed you still feel the transmission is not as smooth as a luxury vehicle should feel.
Old Jan 14, 2023 | 06:18 PM
W205C43PFL's Avatar
Did you realize that I am actually the same person who posted that originally :P lol. That is my thread/post. So, of course yes. It made it better (smoother). But still my complain overall is that ever after it’s fixed you still feel the transmission is not as smooth as a luxury vehicle should feel.
My bad, I didn't realize at all
Old Jan 14, 2023 | 06:41 PM
vinflouen's Avatar
It took a WHILE, you have to go through all the upshifts and all the downshifts.
I made a free afternoon for this task.
But, I will say, this car is BUTTER, smooth now and I'm loving it.
I'm going to have a Weistec tune put on it soon, so I wanted the trans to be fresh.
The trans seems to adapt more and more as I drive, it actually anticipated 6th gear in one case which was a change.
The 5-4 and 3-2 hard shifts are gone as mainly that was my issue, but overall it's much less 'shifty'
Old Jan 14, 2023 | 06:46 PM
W205C43PFL's Avatar
I'm going to have a Weistec tune out on it soon, so I wanted the trans to be fresh.
Good to hear it worked out for you.
Old Jan 14, 2023 | 07:39 PM
vinflouen's Avatar
If anyone else is in NNJ I'd be happy to be of service if they want this done.
with Xentry and a second person, it definitely works.
Old Jan 15, 2023 | 02:02 PM
kafklatsch's Avatar
All Cars Lost To Hurricane Isaac (W124 E420 revived - added 88 Allante 14 S550, 17 S63
Just a PSA.
I am curious as to how prevalent this issue is... we know a forum can illustrate issues which is a good thing... my daily driver S550 and my garage queen S63 both shifts almost unnoticeably ... with the AMG having the expected more aggressive shifting..
.... am I in the minority twice? OR is the problem the minority?
One thing for sure, being illustrated in the forum puts it square in the publics face, and hopefully also in the face of MB...
Old Jan 16, 2023 | 11:16 AM
vinflouen's Avatar
Now I just have to figure out why there is some fluid on the bottom of the splash guard.
hmmmmmmProbably overfilled.....
Old Feb 9, 2023 | 09:15 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
Interesting...My 2017 S500 4-Matic is buttery smooth in all situations, from light acceleration to pedal to the floor.
Old Feb 9, 2023 | 09:25 PM
cfmistry's Avatar
15 S550 4Matic, 86 560SL
My S550 has a very rough 5-4 downshift and an occasionally rough 3-2 downshift. I have had the fluid flushed and software updated, but no changes. I really wish it was “buttery smooth.”
Old Feb 10, 2023 | 08:59 AM
I like how the PDF doc characterizes the problem as "caused by the engine changing from overrun to combustion mode" ... I would have said "starting uphill after coasting under light load" or something, but I think this does describe it well.
Old Feb 10, 2023 | 01:25 PM
vinflouen's Avatar
it was a lot of driving and clicking on the computer to get it to where it is.
a few k miles later, still super smooth.
Old Feb 12, 2023 | 07:57 PM
MBNUT1's Avatar
2010 E350 4Matic
So what exactly are you changing? And how do you know which direction to change it? Just experimentation?
Old Feb 12, 2023 | 08:02 PM
vinflouen's Avatar
you follow the directions in xentry as you drive and hit shift points.
