S-Class (W222) 2014-2020
Fellow S550 owners, please take a minute to read this thread...
Old Feb 26, 2023 | 02:04 PM
Rmayrap's Avatar
2015 S550, 2014 640i
Wonder why fcp euro doesn't sell the cam sensors kit
Old Feb 26, 2023 | 02:06 PM
Rmayrap's Avatar
Originally Posted by MayorMcCheese
Took a moment to check out one of my cam sensors and well... let the picture speak for itself. Only thing I can a bit annoyed that i did was I broke a clip on the harness (right side of the yellowish piece) so I took a small piece of electrical tape and wrapped it around the cam sensor and pushed it back into the harness since a small clip that holds it broke so ill have to add this to the list.
wow good catch. I would change everything out asap, how many miles on your car?
Old Feb 26, 2023 | 02:40 PM
cfmistry's Avatar
15 S550 4Matic, 86 560SL
Again, this reinforces that the main culprit of the harness leak are the cam position sensors, NOT the cam phasers. The cam phasers usually leak onto the cam covers, but not necessarily into the harness.
One important question here - what is your mileage?
Because the part does not exist out of eBay. There is no known manufacturer for it outside of ZZPerformance.
Old Feb 26, 2023 | 02:50 PM
Rmayrap's Avatar
In that case I'll go ahead and order the ZZPerformance kit while it's available
So if we dont see any oil as of yet then simply installing the harnesses on top and bottom will suffice correct?​​​​​​​
Old Feb 26, 2023 | 04:24 PM
cfmistry's Avatar
Correct. That being said, from the data I’ve seen both the sensors and phasers leak by 70-80k miles. So if you’re close, I’d go ahead and replace them.
Old Feb 26, 2023 | 05:38 PM
seamus2154's Avatar
2016 S550 sport, 2018 GLC300, M3, Zo7, 2021 Sierra Denali
Thanks guys for clarifying that and clearing it up!! Now I know what to order. Thanks again!!
Old Feb 26, 2023 | 05:45 PM
  #32
seamus2154's Avatar
ZZperformance is out of stock.
Old Feb 26, 2023 | 05:49 PM
  #33
Rmayrap's Avatar
yea I noticed that as well, I messaged him to see if he will get more in stock. He still has the 8 piece kits though.
Old Feb 26, 2023 | 06:22 PM
  #34
seamus2154's Avatar
Thanks just found it. Ordered the 8 piece kit to get started.
Old Mar 1, 2023 | 01:11 PM
  #35
jcat's Avatar
2017 S550 4matic
bought a kit, figure it's cheap insurance given I'm only at 12k miles but it is a 2017. Does this tend to be more mileage related due to mechanical wear or is it time related like seals going bad?
Old Mar 2, 2023 | 08:30 PM
  #36
Rmayrap's Avatar
my car has 49k miles and showed signs of oil on the plugs and sensors. will be ordering new sensors today.
Old Mar 2, 2023 | 08:31 PM
  #37
Rmayrap's Avatar
Well i went to install the ZZPerformance cam sensors kit and the fcpeuro sacrificial harness today and pulled out the plugs that go into the sensors and what do you know, it had some oil on it. i then pulled out the sensors and noticed some oil on them as well. my question is are the sensors inside supposed to have oil on them or are they supposed to be dry as well? obviously the plugs are not supposed to have oil and indicate a leak from the seals but once the new sensors are bought and installed then its ok for the sensors inside to be oily right? Back to fcpeuro i go...
Old Mar 2, 2023 | 10:52 PM
  #38
seamus2154's Avatar
I received the ZZperformance kit and will be doing the install this week. The quality is very nice. we shall see if there is oil in there, I am at 48K? Thanks again for all the info.
Old Mar 3, 2023 | 01:28 AM
  #39
Rmayrap's Avatar
I would say mileage related since most are showing signs of leaking after 50k
Old Mar 3, 2023 | 04:27 AM
  #40
chassis's Avatar
2017 GLE350 4MATIC
Oil in harness, not new news.
Affects M274/276/278/157 engines.
Fixable with new sensors and magnets. Pigtails are a bandaid and do not address the root cause. But are helpful.
Old Mar 3, 2023 | 06:35 AM
  #41
cfmistry's Avatar
Unfortunately even the newest revision parts still leak. So I would not say it is entirely “fixable” and the pigtails are just another layer of protection.
Old Mar 3, 2023 | 09:09 AM
  #42
jcat's Avatar
2017 S550 4matic
Makes me feel a little better, though I'll be checking for oil in the connectors when I install the pigtails anyway.
At 12k miles I can easily justify the $100 to throw the pigtails at it instead of adding pigtails, sensors, and magnets if I don't really need all of it.
Old Mar 3, 2023 | 03:53 PM
  #43
Grandpa Bee's Avatar
2014 S550 4Matic, 2015 ML400 4Matic, 2019 E450 4Matic Wagon
Well obviously I'm a newbie and an idiot because I can't even get the electrical connectors to release. What is the trick? Stand on 1 leg and stick my tongue out
Old Mar 3, 2023 | 03:59 PM
  #44
Rmayrap's Avatar
unlock by pushing the white pin away from the plug with a flat head carefully then press down on the released pin and pull away.
Old Mar 3, 2023 | 04:23 PM
  #45
YOU Sir are a Gentleman and a Scholar! I've been dinking around with those connectors for 2 hours. I now have 4 sacrificial pigtails installed. Fortunately no oil in any of them. Only 49k on my S550 so that may have helped.
Thank you very much!!
Old Mar 3, 2023 | 04:36 PM
  #46
Rmayrap's Avatar
you're welcome. Did you install only the sensor harness or only the magnet? I would do both if I were you.
Old Mar 3, 2023 | 04:46 PM
  #47
I installed the pigtails on the magnets only. it appears that the sensors are 3 wire and the sacrificial pig tails for the madness are 2 wire
Old Mar 3, 2023 | 06:54 PM
  #48
Rmayrap's Avatar
the sensors are more prone to leaking vs the magnets so I would add the pigtails on the sensors as well.
Old Mar 4, 2023 | 02:51 PM
  #49
OK I have ordered the pigtails from ZZ Performance and new sensors and magnets from FCPeuro
Old Mar 4, 2023 | 05:33 PM
  #50
Rmayrap's Avatar
all you need now are the sensors lol
