There is a space under the door handle (or whatchamacallit) for an umbrella in the front two seats; thank you for posting that whoever did. But no such luck for the rear ones though.
Actually the space I said was for the umbrella in the rear upper door storage pocket area is for a safety vest in other countries. It just fits a small umbrella perfectly.
I use one of them on one side to hold papers (insurance, registration etc) and one on the other side for a couple of cleaners and microfibre towels that I always have with me (effin' mosquitoes).
They are not too big, unlike a floor net, but they are reasonably sturdy and hold well enough.
You can see one in my trunk picture above. I use it to hold the radar detector bag when not in use. I've had this accessory since 2011. Love the Velcro mounting. I never thought to mention this since I've had it so long.
Let me add these to the list of things.
Front Lower Control Arm Adjustable Bushing Kit to fix the excessive negative camber these cars come with from the factory. https://k-mac-camber-kits.com/produc...-s-s63-65-amg/
$385 delivered for the 2 needed bushings, 1 for each side, and some tools and instructions to remove and install the bushing from each arm.
It's worth fixing the negative camber when lowering the suspension to a height below 20-25mm.
It is possible not to correct it if you have a quiet riding mode, the garter is lowered less than 20-25mm and it is worth returning to the factory height for long-distance travel.
In that case, tire wear after lowering will be negligible.
