S-Class (W222) 2014-2020
My 2015 Mercedes S550 Build Journal
Old Mar 1, 2023 | 05:26 AM
chassis's Avatar
2017 GLE350 4MATIC
Subbed. Great thread.
Do you have WIS, EPC and XENTRY? Or just Google/YouTube and mbworld?
Old Mar 1, 2023 | 12:37 PM
Rmayrap's Avatar
2015 S550, 2014 640i
thanks, i just got the car so i just have google youtube and mbworld. Trying to figure out the cheapest and easiest way to get Xentry?
Old Mar 10, 2023 | 04:15 AM
Rmayrap's Avatar
Should be fun...
Old Mar 11, 2023 | 11:00 AM
Robb92914's Avatar
S560, GLS63
Originally Posted by Rmayrap
Today I installed a Pedal Commander. Bought it used off fb marketplace for $120. All i can say is wowaweewa, its very nice! It got rid of that awful lag and now the car feels alive when I want it to be and reserved when I dont. For example when my wife drives it I can tone it down, when I drive it I can adjust to my liking. Any 'PC43' model will work for the Mercedes, they aren't model specific. Also it connects to an app on your phone and can be controlled that way so you can completely hide the unit if preferred. Highly recommend it guys.
hmm never heard of this but interested
Old Mar 11, 2023 | 01:38 PM
Rmayrap's Avatar
If youre into performance get one, youll love it. Trust me. There's one on ebay now for $160 FYI. Just search "pedal commander pc43"
Old Mar 11, 2023 | 05:36 PM
chassis's Avatar
2017 GLE350 4MATIC
Message user @benzninja
Old Mar 11, 2023 | 08:44 PM
  #32
Robb92914's Avatar
S560, GLS63
https://youtu.be/kjJ0_Ppo3ek
Must have sold...I'll keep a look out thanks!
Old Mar 11, 2023 | 09:52 PM
  #33
Rmayrap's Avatar
still on there
https://www.ebay.com/itm/12581404377...mis&media=COPY
Old Mar 12, 2023 | 09:01 PM
  #34
simandang's Avatar
G63/RR LWB/W222 S550
Should be fun...
What’s in this pic? Looks like the jumper harness, cam sensors but what else?
What’s the metal pipes?
Did you have any oil leakage? How many miles?
Old Mar 12, 2023 | 11:59 PM
  #35
Rmayrap's Avatar
I will change all the sensors, solenoids and add the harnesses as prevantative maintenance to make sure my ecu and engine doesn't get damaged by the leaking oil issue these engines develop from the wire harnesses. While I am there I decided to change out all my idler pulleys, tensioner pulley and drive belt. Also will change the oil. The pipes are the stock charge pipes I just removed to clean them up a bit since they were very greasy and dirty from 8 years of use.
Old Mar 13, 2023 | 09:59 AM
  #36
simandang's Avatar
I changed all the sensors, solenoids and added the harnesses as prevantative maintenance to make sure my ecu and engine doesn't get damaged by the leaking oil issue these engines develop from the wire harnesses. While I was there I decided to change out all my idler pulleys, tensioner pulley and drive belt. Also changed the oil. The pipes are the stock charge pipes I just removed to clean them up a bit since they were very greasy and dirty from 8 years of use.
Do you have the part numbers for everything you did? That’s next on my list, I was going to do the jumper harness but I might as well do the whole thing. I got my 15 last fall.
I did a complete facelift on the front end on mine
Old Mar 14, 2023 | 01:46 AM
  #37
Rmayrap's Avatar
All items can be purchased from fcpeuro except the camshaft sensor harnesses, those you need to get from ebay. There's a seller named zzperformance_esales that sells the kits for 59.99
Mercedes Serpentine Belt MER-0029936796
Mercedes Drive Belt Tensioner GAT-902642
Mercedes Drive Belt Idler Pulley INA-5320108100
Mercedes Idler Pulley FEB-49372
Mercedes Idler Pulley FEB-49371
Mercedes Idler Pulley FEB-102153
Mercedes Camshaft Position Sensor Kit KIT-2769051000KT1
Mercedes Camshaft Solenoid Kit KIT-2761560790KT
Mercedes Camshaft Solenoid Harness MER-2711500156
Old Mar 14, 2023 | 01:56 PM
  #38
simandang's Avatar
Isn’t this the jumper harness from fcp
https://www.fcpeuro.com/products/mer...des-2711500156
thx for the list I will orders it all
Old Mar 14, 2023 | 02:25 PM
  #39
Rmayrap's Avatar
those won't work for the sensors, you need a 3 pin version that fcp doesnt sell.
Old Mar 19, 2023 | 03:23 PM
  #40
simandang's Avatar
thank you
ordering everything today
did you flush out the driveline fluids yet? I need to do that as well. Thinking of doing it while doing the sensors and a LOF
Old Mar 19, 2023 | 07:16 PM
  #41
Rmayrap's Avatar
thank you
I have 45k miles on mine, all I will do is change the air filters, oil filter, cabin filters and oil. I should be ok on the other fluids for now.
Old Mar 26, 2023 | 08:24 PM
  #42
cfmistry's Avatar
15 S550 4Matic, 86 560SL
Next up were wheel spacers, I wasn't sure how aggressive I could go so decided to play it safe and went with 15mm rears and 12mm fronts. Spacers are made by Bonoss and are very high quality and lightweight forged and hubcentric. No issues, no vibrations. However I'd recommend 15mm all around for a slightly more aggressive fitment, the rears are good but the fronts can come out a bit more for my taste. Yes I know my mirror is missing lol
Thanks to your post I ordered 15mm/15mm Bonoss spacers so I just wanted to say thanks! I was originally going to go 12/12.
Old Mar 26, 2023 | 08:41 PM
  #43
Rmayrap's Avatar
Good deal, I ordered 15mm for my fronts as well. The 12mm wasnt cutting it for my taste.
Old Mar 31, 2023 | 07:21 PM
  #44
Rmayrap's Avatar
I've been a busy man with the repairs/mods lately and wanted to update you guys with the progress.
The repairs...
I spent all day yesterday installing all the new pulleys, belt, harnesses, solenoids, sensors etc...
Removed and cleaned all four charge pipes.
Changed the oil and filter and added some Ceratec to the engine.
Car runs much quiter and smoother now.
The mods...
- Had the chrome window and trunk trim wrapped to gloss black
(sorry @cfmistry lol)
- Installed gloss black brabus style diffuser with brabus style exhaust tips
(Dont like the third brake light on it so will have that wrapped gloss black soon)
- Installed lowering links in front only
(Was sent wrong links for the rear so waiting for replacement)
- Changed out the front spacers from 12mm to 15mm to get a slightly more aggressive stance
She's still under construction so dont judge me yet lol
Old Mar 31, 2023 | 10:16 PM
  #45
cfmistry's Avatar
I've said it before -- I'm not a murdered-out kinda guy, but you're doing it right. With the rear links on there it will look great. I am about 3/4" lower than stock via STAR lowering.
Old Mar 31, 2023 | 10:18 PM
  #46
Rmayrap's Avatar
Yes sir. Gotta leave some chrome. Btw did you ever install your spacers?
Old Mar 31, 2023 | 11:51 PM
  #47
Donnymac's Avatar
63 Falcon vert
Well done project!
Old Apr 1, 2023 | 01:40 AM
  #48
Sean._.S's Avatar
S550
The repairs...
The mods...
What a beauty. Have had my S550 (black on black likes yours) for 3 years and never did anything to it. After seeing yours though, I'm getting inspired...
Old Apr 2, 2023 | 08:50 PM
  #49
cfmistry's Avatar
Sure did, and they fit great. The Bonoss stuff is quality for sure. Pictures are for reference for other owners.
Old Apr 7, 2023 | 02:27 AM
  #50
Rmayrap's Avatar
Got the rear links installed and added black "amg" valve stem caps and smoked license plate cover
