S-Class (W222) 2014-2020
Fuel Additive?
Old Feb 26, 2023 | 11:15 AM
S_W222's Avatar
Current/Last 5-years:GLS;G70;Alpina B8;X7;Accord. Sold:X7,TeslaS;S560;S550,X5;530e;L.Navigator;LS460
Fuel Additive?
  1. What do you all use as a Fuel Additive/cleaner/etc from time to time (either cleaner or enhancer) and how often should I use it for the S560 4-Matic?
  2. I will use 91 octane gasoline from Costco going forward (thoughts on that too?).
Old Feb 26, 2023 | 12:24 PM
NJ560's Avatar
2019 S560
I run Liqui-Moly through it around every 3k miles. We have 93 here in the NE, so I’m running on that 95% of the time.
Old Feb 26, 2023 | 12:41 PM
S_W222's Avatar
Is it this one that you use: LIQUI MOLY Jectron Fuel Injection Cleaner
https://www.autozone.com/fuel-and-en...B&gclsrc=aw.ds
Old Feb 26, 2023 | 01:11 PM
vinflouen's Avatar
2019 W222 S560 4Matic/2025 Yukon Denali
Chevron Techron.
thats it every 5k miles
Old Feb 26, 2023 | 01:16 PM
cfmistry's Avatar
15 S550 4Matic, 86 560SL
Top Tier gas is most important. It means that the fuel is relatively clean and the tanks that hold the gas aren’t too old. Costco is Top Tier so you’re good there.
If you read forums like BITOG, which is mostly engineers and chemical junkies, you will learn that additives do almost nothing if the car is well cared-for. Top Tier fuel + frequent OCIs is key.
I run a bottle of Techron (20oz) every year but I don’t think it does a damn thing. If it makes you feel better, you can safely do the same.
Old Feb 26, 2023 | 02:11 PM
NJ560's Avatar
2019 S560
Yes, the Jectron is what I use. I also use top tier 93 octane, so whether it does anything or not I don’t know. But for $30/year if it does even a little bit that’s fine by me.
It does help the Suburban noticeably. That V8 likes a good chemical reaming!
Old Feb 26, 2023 | 03:06 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
Throw in a bottle of Techron once a year or so. My cousin is a Chevron exec and I own the stock, so have to support the home team ;-)
Old Feb 26, 2023 | 04:39 PM
konigstiger's Avatar
'71 Pinto
MB approved Techron Concentrate Plus
Old Feb 28, 2023 | 03:54 PM
badq45t's Avatar
2016 S550e, 2005 Nissan Xterra 4x4, 1984 300ZX
I run FCP every 6 months, cannot say if it works but Techron has been used in my 1984 300ZX and 2005 X-Terra for a million years and I haven't had one single issue with fuel injectors so will continue to do so
Old Mar 8, 2023 | 11:56 PM
Gene Gorman's Avatar
05 SL55, 10 C63, 12 SLK3, 20 S560, 08Bentley GT Speed, 16 Aston Martin Vanquish
I always use Shell 93 with Techron. Shell 93 has Techron in it. Been using it for the last 10 years.
Old Mar 9, 2023 | 11:43 AM
Jud Chapin's Avatar
'16 S550 Coupe, '11 Lexus LS460, '02 CL500 (SOLD)
This stuff is a complete waste of $. Fuel today has cleaning additives. I've been driving fuel injected cars since '91 and have never used additives and have never had a problem. Gasoline producers wouldn't last long without cleaners.
Old Mar 9, 2023 | 11:56 AM
S_W222's Avatar
I figured it would have minimal benefits if any, but as you know, in most cases we do these things as a piece of mind [mental health ...]. So, it still works at least mentally and the money does worth that feeling despite that it may have done nothing to the car, lol....
Old Mar 9, 2023 | 02:02 PM
jcat's Avatar
2017 S550 4matic
on modern direct injected cars it isn't as important to run cleaners because they don't wash the back of the valves etc. anyway. That being said, I have to think there would be some benefits to additives that lubricate the fuel system like the Lucas fuel system treatment. Gasoline being such a good solvent, I'm not sure how well the lubricants would survive in the system, but I could see it helping the injectors at the least.
There will always be a little carbon that can work its way past the rings, oil from the PCV that enters the cylinders especially on these turbo engines and don't forget the spark plugs as well. Modern high quality gas does have detergents, but adding some more will only make the cleaning action stronger. I can say for sure, I put two cans of Berryman in the F350 I bought (30ish gallon tank) because the 5.4 is port injected and god only knows how well it was maintained, and purely by the smell of the exhaust I could tell that stuff was working!
