S-Class (W222) 2014-2020
Oil Change Quantity
Old Feb 27, 2023 | 03:05 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
Oil Change Quantity
Can someone who's done it confirm the number in the manual, an oil change with filter requires 8.5 quarts.
For a 2016 S550 with the standard M278 / 4.7L engine.
Old Feb 27, 2023 | 03:17 PM
2012 merc amg's Avatar
2018 S560
I thought it was 8.9 quarts. At least you have a dipstick so you can double check it. My 2018 has no stick and according to the onscreen gauge after putting in 8.9 quarts its right up on max and sometimes turns red and says overfill on rare occasions. Strange. I really wish MB had not done away with the dipstick, for that matter too a trans dipstick, it had been that way a long time and I'm sure not much fluid evaporates outta the cars with the trans sticks that have a good o ring seal on the dipstick.
Old Feb 27, 2023 | 03:38 PM
konigstiger's Avatar
'71 Pinto
And service sheet shows 278.929 = 8.0
File Type: pdf
Old Feb 27, 2023 | 04:44 PM
Ah, 8 liters = 8.45 quarts
Last time my Indy double-checked it using xentry when I had the car in for something else. Maybe it's just me, I have a hard time reading the dipstick, the entire end is covered in oil well above the red thing.
Thanks!
Old Feb 27, 2023 | 04:59 PM
AMG__POWER's Avatar
2024 c300 , 2006 E55, 2005 e320, 2007 gl450, 2025 glc300, 2025 e450
I use the liquimoly kit from fcp euro, it is 8.5 quarts I believe, I add 2 cans ceratec as well.
Old Feb 28, 2023 | 12:45 PM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
Thanks!
You need to thoroughly dry the end, insert, remove and look closely with a light if needed and turn the stick slowly, you will clearly see shiny area where oil mark stops. NOTE: most of the time when removing the dipstick, you fill find it dry as a bone. This is normal I found out due to the vacuum in the engine causing oil to be sucked out of the stick. Remove / insert all good to take a reading. Some people have taken this 1st reading and ended up overfilling oil.
Old Mar 7, 2023 | 05:03 PM
Just to close this up ... my guy put in exactly 8.5 qts today and car was down a half when I got it home and checked the dipstick ... so at least for my car, the correct number is 9.0.
Old Mar 8, 2023 | 10:01 AM
jcat's Avatar
2017 S550 4matic
8.5 plus filter volume would probably be about 9.
Old Mar 9, 2023 | 04:39 PM
Again, the manual says 8.5 quarts with a filter change ...
As I think about it, my Honda's transmission is supposed to take 3.0 qts for "drain and refill" per the manual and it actually needs 3.5 to show correct (full) level. Maybe mfgs are a little on the low side generally?
Old Mar 9, 2023 | 04:58 PM
2018 S560
The dealer I go to up north where I know the long time mechanic says he always puts in 83/4 quarts to be safe but told me to put it exactly on full it’s 8.9 quarts.
Old Mar 10, 2023 | 02:37 AM
ebceksl's Avatar
Mercedes S 500 4MATIC W222 (2015)
I have changed the oil in my M278 several times. I drain the oil via the plug in the oil pan, and then fill up with 8 liters. Then the oil level will be perfect when I measure the oil level when the engine is cold.
Old Mar 10, 2023 | 12:16 PM
steinjr's Avatar
Veteran: Army
2015 S550 4MATIC
Only change the oil when the car tells me to. Don't quote me... but I believe the car calculates how often it is started, how far it is driven, and how long since the last maintenance reminder reset and uses an algorithm to determine when the next service is required.
Old Mar 10, 2023 | 02:45 PM
2018 S560
I thought it was just every 10K miles or 1 year whichever comes first. I know I had a chevy that worked on some kind algorithm depending on how hard the car was driven and conditions to trip the oil change due light so I know there are some cars that have this type of system, so maybe although I never noticed that on the MB, just seems like miles or time, which yes someone that drives like 2K miles per year or less they probably don't need an oil change every year although the darn reminder is gonna stay on all the time after a year of not changing the oil.
Old Mar 10, 2023 | 02:54 PM
jcat's Avatar
2017 S550 4matic
realistically the only way to know for sure is to have the oil analyzed.
These cars hold more oil than normal, which makes an increased interval less risky. That said, with these DI turbocharged engines 10k still makes me a little iffy at least with the way and conditions in which I drive. On the old N/A v8's, sure. I'd probably do 7500 honestly. But that's just me.
Old Mar 10, 2023 | 03:09 PM
2018 S560
Ya, I go 10K miles, with the quality of todays synthetic mobil 1, the good fleece filters, and like you said the nearly 9 quart capacity I don't worry.
