Dealer Says New Pads & Rotors - How much should I expect?
I have a 2015 S550 with almost 67,000 miles. The car is at the dealership getting the "A" Service, since it just had "B" in the summer. The car had new brake pads and rotors replaced when I bought the car at 43,000 miles, about two years ago. Is it normal for pads and rotors to wear this fast? and how much should I expect to pay? I got the service video sent to me today, but the advisor hadn't called me back yet, but the technician in the video said that they are in the yellow, and the rotors have a nice "lip" on them. Also, have an oil leak that they found that they have to diagnose.
Thanks again!
Thanks again!
I wonder of their vehicle really eat through pads and rotors or if dealers are taking advantage of everyone…
23k miles is quite terrible unless (a) the brakes and pads were not actually replaced when you bought the car or (b) you are really hard on your brakes. This obviously assumes that the dealer or tech looking at them now are honest.
Given this seems a bit unusual I would probably either check them yourself or get a second opinion on the current wear.
I have 21k on my brakes and pads and they arent even half worn.
Or just wait until the brake pad sensor on the dash goes off (I assume this hasnt happened yet)?
I know working on cars isn't for everyone, but brakes really are not difficult to DIY. You can ensure you get the quality of parts you want and know for a fact it was done right.
23k does seem short but also they are recommending an early replacement, I always wait for the sensor to trip but if you can't have the downtime you might want to replace early.
It is how you drive the car.
I quit using Distronic Plus because of the way it slams on the brakes any time the car starts to creep above the set speed. And for several other traits it has that has to do with slamming on the brakes when I ABSOLUTELY do not want the brakes slammed on.
I am at 40K miles on my 2015 and still have 2/3rds of the pads left.
On the other hand, I get 20 MPG in my 5,000 pound V12..........
It is also not tunned to really use engine braking so the slowing down goes to the brakes.
I would take the wheel off and examine the rotors and pads up close, post a pic if you want and maybe we can help.
I see the powerstop z23 kit for front and rear on rockauto at $832.79, about $40 cheaper if you didn't have drilled rotors from factory. That's fairly premium level parts with ceramic pads.
FCP shows genuine mercedes rotors with pagid and jurid pads at a grand. That's factory level equipment for 20% of what the dealer quoted you. I'd bet even someone who's never done brakes before could probably do it on these cars with the right tools in half a day.
I was at about 30k miles. When I called the independent at first he was like "lets see if it really needs brakes" and he had me come over and he put it up on the lift, but sure enough it needed brakes. My LS460s needed front brakes around the same time, the rears were fine but I am told Distronic uses the rears and wears them more quickly.
It all depends on how you drive it. I drive my cars fairly hard, I hardly ever have a set of front brakes last more than 30k miles. The surprise on the S Class was the rears, but I attribute that to the distronic.
I do have pads and rotor set from MB that cost me about $1200 for all parts.
maybe another 400 for labor to do it.
Thanks everyone for your posts! Everyone was very helpful. The service is completed, and there is a minor oil leak that they are diagnosing and then fixing. However, the advisor called me and said that there is "still life" left on the brakes, and he sees me at least getting to my next service. He even said, "I wasn't going to mention them to you because they are at 5 mm." Totally fine. I said thank you very much!
