ILS+ INTELLIGENT LIGHT & other codes done, FULLY REMOTE! NO RENTAL hardware, low cost
Thank you !
Pricewise we now offer free mods
also full rental refund, diagnostics, repair help
We ONLY do Premium MB security spec coding
There is no secure coding with a $30 plug.
That is a joke, irresponsible and dangerous
Unbelievable that people would who own a 50-160k car want to save a a dollar with the risk of damaging their car
So different, a real Artist !
Same as you Donnymac
BenzNinja has my highest level of recommendation too !
“4-cylinder deactivation”, described as ZAS in some technical documents, is possible if:
• ECO start-stop system active, not deactivated via the Start / Stop key “—> so this means, if you turn it off, ZAS will be of too!” wierd connection between the two.
• Coolant temperature> 46 ℃ depending on the surrounding temperature and
requests for heating the cabin
• Comfort or ECO driving program from 2nd gear
• Vehicle speed> 18 km / h at engine speed <1600 rpm ("DCT")
• Vehicle speed> 45 km / h depending on the comfort request ("NVH")
• Catalyst temperature> 320 ℃
• Intake air temperature> -30 ℃
• Battery voltage> 10 V
ZAS not possible if:
• Coolant temperature> 110 ℃
• Sport, Manual driving modes, and during manual gear shifting
• Vehicle speed> 170 km / h or engine speed> 3800 rpm
Would be nice to see the source of your copy/paste
Just sharing my experience working with one of the companies who are well known in the hardware retrofitting coding area for German cars based on what I concluded from their previous work and reviews. After I recently learned they are the only one offering W223 coding and successfully helped some members here, I asked few members if they tried him for W222, and answer was positive.
I did extensive review of his previous work in BMW forums and his reputation is high, so I contacted him to learn more about his services for Mbenz and W222. He was easy to work with, responds immediately on WhatsApp, he always does a (connection test) before you pay a single penny, and offer a nice gesture of free AMG theme coding (at least in my case) before booking a formal/final appointment for all you coding needed. Plus, they do not have any minimum coding service amount.
I hired them as they offered me ONE THIRD the cost that other coders are asking for (I did not negotiate, simply accepted, fair enough). They also do coding FULLY REMOYTE without requiring you to buy any equipment that must be shipped to you, and without you needing to pay for renting any equipment (so no shipping delays back and forth, lower cost, etc.). It is all 100% remote, and you only pay reasonable amount for his coding time which was really quick.
Process (finished same day, took 2 hour from first contact to finish):
- I contacted them around evening US time "morning time for them" (they have WhatsApp number ). Responded within 15 minutes.
- All I needed is a cable from Amazon for W222 (if you have W223, ENET cable "OBD-to-Ethernet" is all you need which you may have already or find anywhere locally or $20 Amazon). For W222, if you don't have it already, he can suggest you a 30 bucks OBD-to-USB cable from ebay (also available on Amazon Prime) which I already had in advance as I used it before for coding on my BMW X7.
- Once cable connected to my laptop, via TeamViewer he did my coding in 15-30 min coding (he stores a backup of your initial settings)
- I did ILS+ (amazing how it works)
- And I also did (Engine Auto Start/Stop last setting memory) coding.
- He did some AMG logos and theme coding for me at no charge. I thought about europ-spec's height which he can do, but still not sure if I really want it; might try it later for a few days and reverse it if I don't like it.
- After coding was done, he called me on WhatsApp and had his camera/video opened to check on everything and that all was good and am happy with the service. The video chat call made the experience a bit more personalized and makes you feel comfortable that you know who you deal with. He stayed with me during a test drive and also walked me through the menu step by step to make sure I know how to control the new features I got and that they are working.
A few members here on the W222 have already hired him, and that's how I knew him. They are welcome to share their experiences here too.
Photos from my car:
Was a breeze working with him and very fair pricing for coding. Got the Openport 2.0 from aliexpress for $30 waited a few days and the coding process took about 1 hour.
Super responsive, explained everything and video called to check functionality after coding.
While doing research got my own setup running with xentry xpt, vediamo and DTS. Loads of weekend research coming up 😀
Ambient light detection question to all:
Trying to figure out if anyone has found how to code/adjust lux level where ILS kicks in or is it a combination of lux and object detection?
How MBZ changes control unit structure between models is beyond me but guess that's how they roll :-)
From the little testing I've done so far DTS Monaco projects would be the way forward for coding and Xentry for full diagnostics and reporting. Vediamo is good for quick changes.
My entire setup is on a Vmware VM and would be more than happy to share so it will be click and go as long as you have VMware workstation. Although there are few changes in the .vmx file you will have to do on your setup for Xentry to work.
A weekend sounds good!
Glad to see many satisfied cliens here and we are here to support you and unlock the full potential of your Mercedes in software coding or via hardware retrofit. My whatsapp: https://wa.me/6597335000, youtube chanel: https://www.youtube.com/@myelebest, facebook EleBestSG, email: elegps@gmail.com, or visit my workshop in Singapore(if you happen to travel here or you stay in Singapore): Save my number now: +6597335000 as "Max EleBest" or "Max EleBest SG" in your phone, you have a new friend from Singapore. Cheers!
1 Bukit Batok Crescent, 04-19, WCEGA Plaza, 658064, Singapore, Office tel: +65 6635 O518,
https://rjautomotive.net/pages/coding-options
For USA 222/213/214/223/206/254/294/295/296/297: Mostly coded are ILS+ and Digital Light Animation and AMG/Maybach stuff.
For older model: we need a device J2534 compatibility: OpenPort2.0, 5054 (used for vag group), C4 or C5 or C6, etc and sometimes need enet cable (yes. exactly same cable as BMW)
For newer model like 223 206 etc, enet cable
and
A native windows laptop and Fast and Stable internet at your garage.
Enet cable is $10-20, Openport2.0 is around US$20-40, in amazon or ebay or other shop available near you,
and
