2015 S550 purchase questions
Hi, I'm considering purchasing a 2015 S550 with 44,000 miles on it. It's a one owner, clean Carfax vehicle. I test drove it a few days ago and it looks to be in excellent condition. I'm coming from a C43 and have no experience with S Class cars. How important is it that I ask to do a pre purchase inspection at a Benz dealership? I know that motor mounts can go, what else should I be looking for on a 2015 with 44,000 miles? Any help is much appreciated.
At that mileage I would check the following:
Motor mounts
Oil leaks
Suspension bushings for cracks
Brake wear
Tire wear
All basic stuff. There are no common issues at that low mileage, but age is creeping up.
Once you get it you will need to add harness extensions for the cam phasers and sensors, but that's a relatively cheap and quick fix ($150 and 1 hour of your time).
Motor mounts
Oil leaks
Brake wear
Tire wear
Ryre (04-03-2023)
The M278 is notorious for oil leaking from these areas, traveling through the engine harness, and ruining the ECU. It is a very costly repair (engine has to come out to replace the harness) but a very cheap preventative move.
Well, the PPI went well. Only thing they found was a fault code for CD player that the dealer said the will take care of before I take delivery. Car is really clean, has a few nicks here ant there but they are all in paint protection film. 2015, 4 matic, 1 owner, clean carfax, 44,000 miles. Paid $38,500. Seems like a fair price compared to what I've seen. Thoughts? Comments? Anything is helpful. As I said, I've never had an s class before. CARFAX One-Owner. Clean CARFAX. Priced below KBB Fair Purchase Price! 2015 Mercedes-Benz S-Class S 550 4MATIC® Magnetite Black Metallic 4MATIC® 7-Speed Automatic 4.7L V8 BiTurbo ORIGINAL MSRP $110865 4MATIC® Nut Brown/Black w/Exclusive Leather Nappa Upholstery Active Blind Spot Assist Active Lane Keeping Assist Active Multi-Contour Seats w/Massage BAS PLUS w/Cross Traffic Assist CMS Lane CMS Rear Comfort Box Control Code Driver Assistance Package Control Code Premium 1 Package Control Code Warmth & Comfort Package DISTRONIC PLUS® DISTRONIC PLUS® w/Steering Assist Driver Assistance Package Front Heated Armrests Front Heated Seats - PLUS Hands-Free Access Heated & Active Ventilated Front Seats Heated & Active Ventilated Rear Seats Heated Steering Wheel KEYLESS GO® Memory Rear Seats PARKTRONIC w/Active Parking Assist Power Rear Seats Power Rear Side Window Sunblinds Premium 1 Package PRE-SAFE® Brake PRE-SAFE® PLUS Rear Heated Armrests Rear Heated Seats - PLUS Warmth & Comfort Package.
Also, please get the harness extensions I referred to. If you search around the forum you will find more info. It affects all M278s.
Ryre (04-08-2023)
Just to pile on a little, congrats, sounds like a really nice car! I had a C350 before and the S class is really a whole different world. I thought about going to an E but glad I skipped that and went right to the flagship model, it's that good.
Do you have the 360 deg surround camera, that's really helpful in tight spots since the car is so big.
Following - I'm considering a very similar purchase - 2015 - clean carfax - dealer service history - around 50k miles. Coming from a W212 that has been very solid. Nervous about the step up but very tempting.
Finally picked it up today. It poured all day, so no pics to post yet. Im pretty disapointed to find out that mbrace isnt supported on it. I used the remote start a lot on my 2017 C43. Anyone know of a reliable aftermarket remote start option?
Here's a guy selling a set for both cam position sensors (3 wire) and cam adjusters (2 wire) ... 8 pcs total.
https://www.ebay.com/itm/17091548172...kAAOSwyb1jWuLX
Ryre/jimh6,
Read the threads about oil in wire harness prevention, front cam covers oil leak/rear cam plug oil leak, unplug oil pressure solenoid, air box spacers, oil filter housing seal, oil/coolant cooler seal, turbo coolant lines, electrical grounds, silitec/nanoslide cylinder liners, cam correction factor, motor mounts and vacuum lines/oil separator to get a good grasp on this engine. All cars have inherent issues but at least most of these issues can be taken care of. M278 engine can be a beast of an engine if you take care of it. Get Benz-ninja for at home/on the road custom coding/diagnostic assistance and avoid the dealership.
Received 3,417 Likes
2012 CLS63
If anyone is local near me (Chapel Hill/Durham, NC) I have a set of beige, all weather OEM mats from the 2014 S550 I had, no charge....just wanna get rid of them.
cam sensor harness I ordered
I ended up ordering these from ebay for $31.99:
M278 cam wire harness set
I linked a different seller. The 1st linked seller is still at $99. Interesting that when one looks at the 1st linked seller's sales history on ebay they used to sell them for $24 then bumped price to $99.
I messaged that seller yesterday. They said it fits my 2015 S550.
13 s212 63 p30. 03 s55amg. 06 LX470
Ryre/jimh6,
op, read up on this issue, many here worry about it. It can be inspected. Make sure it’s inspected before any warranty runs out. It is a must, or buy an extended warranty and then inspect.
