S-Class (W222) 2014-2020
W222 Fan constantly running
Old Jun 23, 2023 | 03:33 PM
Lucalena's Avatar
Mercedes S350 w222
Hi all, I hope someone can help!
I have a S350 2014 W222 which has recently been causing me some headache. Sometime yesterday the AC went from ice cold to somewhat warm, shortly after this I noticed the fan was constantly running on high. I started the car this morning and the fan come on a couple seconds later again running on high and only goes off once the car is turned off. I’ve also noticed the outside temperature reading is wrong, it’s showing -33c (I live in London UK it’s 25c).
Fault code:
B10VA 15
The refrigerant pressure sensor has a malfunction, there is a short circuit to positive or an open circuit.
I spoke to a local garage who said it will be a lot of work to get to the RPS and they’re not sure it will actually solve the issue. I’m hoping to speak to a Mercedes specialist on Monday and get this figured out.
Perhaps anyone here has had a similar issue and can shed some light on possible fixes?
Old Jun 27, 2023 | 07:44 PM
vinflouen's Avatar
2019 W222 S560 4Matic/2025 Yukon Denali
Did you mean b107a15 code?
Old Jun 28, 2023 | 02:41 AM
BenzNinja's Avatar
Former Vendor
Fault code:
B10VA 15
it's a two in one sensor apparently located at the base of the condenser radiator
of course the circuit will be open during replacement so a full refill required
access seems not crazy but sometimes you get some access surprises with modern Benz, I would attempt from under the car
first thing to check is the connector for corrosion, due to it's function, location and Uk's horrible climate for cars, you might find some
