hard to line up radar detector with windshield cut out
The one at the bottom next to the auto windshield wiper sensor, is too low and i cannot get my radar detector angle correct to be able to look straight thru the cut out and also look straight onto the road. the only way i can make it look is pointed downwards but then it it looking at the hood and there isnt any soace to tilt the other way since the dash area is in the way of my radar
the only other spot is passenger side near the pushdown makeup mirror thingy, but over there the headliner is too thick at the spot where the cut out is so if i try to position my radar detector and mount it so it looks thru the cut out, it ends up hitting the headliner and makes it impossible to look straight.
the radar detector should have a str8 line up sight thru the windshield and it is so hard for me to place my radar so that is possible
anyone have a work around? my unit is even a small one its just a uniden r3 so it is really compact
thx!
thx!
Center Mount
I have a friend who has a Netradar DSP install, and the front radar head has zero obstructions, i.e., best possible exterior position.
They were traveling with an Uniden R8 so mounted it dead center in the windshield (not in either cut out) to see how badly the windshield impacted range. They do not have the heated windshield option.
Over about 10 Ka hits during a long east coast drive, the R8 alerted anywhere from a split second to 2 seconds later than the NR. The R8 never alerted first, but the NR had about 5 feet and zero obstruction advantage.
Even with the R8, the alert was so far out that there was more than enough time to reduce speed.
On K, though, the R8 had almost no K alerts at all, which seemed odd. None of the K alerts were police, so they cannot say if the silence is because the R8 is newer/better at filtering K than the NR, which people say is effectively an Uniden R3.
edit: read more about the parking sensors and distronic messing with the signal. even if thats true, if i never use distronic then those sensors wont set off the R7 , correct? i realize every time i put it in R to park in the garage etc it may signal but i could deal with that. just curious if there are more sensors id have to worry about with the radar detector
thx!
A long time ago, I used used a detector. - then, I just starrted driving within the allowed speed limits. No worries.
In Houston and much MUCH more relevant in LA, people drive 25 mph over the limit on the interstates
If you get in the right lane and drive at posted you will get shot at
So i drive with slow traffic ( still fast enough to get a ticket) and slow down when the detector says so ...for a few seconds... i consider it removing myself from russian roulette ticketing
So the detector keeps me from being RAGED AT....
Houston is much more manageable in this regard
