S-Class (W222) 2014-2020
Can the 3D trunk subwoofer be replaced?
Old Nov 15, 2023 | 03:32 PM
wheatswake's Avatar
2017 S550 coupe, 2013 E550 coupe, 2008 Tahoe
I have been looking for someone talking about replacing the factory trunk Burmester 3D subwoofer for a different sub but have not found it. Is it possible? I know Focal is making the ISUB-MBZ for the inside dual sub replacement but have not found anything on the single trunk sub replacement. I know ohm level would have to match but if the factory amp has a frequency restriction and its not worth doing then that would be good to know. I have a S class coupe but would assume the same principle applies. Thanks for any input.
Old Nov 15, 2023 | 07:39 PM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
I did this on my 2019 S63. Replaced the sub and sub amp in the trunk. Could never get the amp to behave with the Burmester post processing so just swapped in a Morel sub and wrapped the box with sound deadening and reverted to the factory sub amp that is the size of a box of playing cards. Helped a little bit, not enough that I would do it again though.
Old Nov 16, 2023 | 08:16 AM
wheatswake's Avatar
Thanks for the replay. Yeah, i was not planning on replacing the stock amp, just a simple sub swap. I wonder if Benz Ninja can do any coding on the amp?
