S-Class (W222) 2014-2020
Another TPMS question?
Old Oct 12, 2023 | 07:46 AM
zitsky's Avatar
2020 S560 4Matic
Do you reset by swiping down on left touchpad? I was pressing it. Do you reset when cold or warm?
Also the pressure in the gas cap? That’s cold tire pressure?
Old Oct 12, 2023 | 08:43 AM
will_atl's Avatar
2020 S450 4Matic, 2022 GLS450 4Matic, 2015 C300
Set when cold, using the pressure inside the gas cap, I target somewhere in the middle of min and max load. Once you have set your tire pressure, cold, drive for a minute or two and they should show in the TMPS screen, and it's either swipe down, or press, the left touchpad to set these pressures as your new target values.
