S-Class (W222) 2014-2020
Squeaky Driver’s Seat S560
Old Feb 26, 2023 | 10:17 AM
NJ560's Avatar
2019 S560
I have a driver’s seat that creaks/squeaks when I shift my weight or go around a corner. Had it at the dealership for some other things, and had the tech check the seat.
They wanted $3200 (!) to fix the seat, apparently there is a felt or something that wore off the springs. I have no problem spending to fix the car, but I couldn’t bring myself to spend $3200 on what is most likely a $5 spring.
I understand labor is labor, but that seemed excessive.
Couldn’t they just replace the backrest? I would spend $3,500 if it was just a brand new backrest. My gut is that they take the seat apart and it will never be the same again, like all the springs popping out of a watch.
Thoughts from the brain trust?
Old Feb 26, 2023 | 10:25 AM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
I had this issue, you're out of warranty? They fixed mine with a ton of felt and its never come back.
Old Feb 26, 2023 | 10:33 AM
NJ560's Avatar
2019 S560
Of course…. About 2 months out of warranty 🤦🏻‍♂️
Old Feb 26, 2023 | 10:34 AM
SW20S's Avatar
2024 S580
Ugh...
Old Feb 26, 2023 | 10:55 AM
konigstiger's Avatar
'71 Pinto
At cost repair, certainly they can replace the backrest if you request it but still involves removing & disassembling the seat. Crazy thought, 60 days out of warranty see if MBUSA will approve goodwill repair. Attached bulletins will give you an idea of possible repair solutions.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Feb 26, 2023 | 11:38 AM
NJ560's Avatar
2019 S560
Ll91.1 0-P-057914 Describes the issue exactly.
For the goodwill service, do I talk to the dealer or should I go right to MBUSA and contact them.
I double checked the warranty and it’s in fact 23 days out, not even 60!
Old Feb 26, 2023 | 01:33 PM
cfmistry's Avatar
15 S550 4Matic, 86 560SL
My seat “rocks” or “clicks” on acceleration and braking. Not really any noises. Is this the same issue?
Old Feb 26, 2023 | 02:13 PM
NJ560's Avatar
2019 S560
Seat doesn’t move. It’s a creak in the backrest if I move or go around a corner and the car moves me.
If it was $1,500 to fix it, I would have done it already. $3,200 was a no on principle.
Old Feb 26, 2023 | 02:49 PM
SW20S's Avatar
2024 S580
If yours had this creak, you would know. Its AWFUL. Mine had it brand new.
Old Feb 26, 2023 | 04:44 PM
'71 Pinto
Originally Posted by NJ560
For the goodwill service, do I talk to the dealer or should I go right to MBUSA and contact them. I double checked the warranty and it’s in fact 23 days out, not even 60!
if vehicle has been serviced regularly by this dealership speak with Service Manager to contact MBUSA on your behalf. If not, contact MBUSA 800-367-6372.
Old Feb 27, 2023 | 02:11 AM
BenzV12's Avatar
W212 FL
I see your point , for a cheap fix they want an exorbitant repair fee . Well, how about using WD40 ? It may not be a a temporary fix but should be cheaper than dealer's quote
Old Feb 27, 2023 | 08:13 AM
SW20S's Avatar
2024 S580
I wouldn't go taking the seat apart and spraying WD40 all over it in my car, personally...
Old Feb 27, 2023 | 08:34 AM
PeterUbers's Avatar
have they known about it in a previous complaint while in warranty period? Did they attempt a fix? If so then you have more of a push for goodwill. Also just call mbusa and ask them to hear your concerns about 23 days out of warranty.
Old Feb 27, 2023 | 10:05 AM
QuadBenz's Avatar
Mercedes, Porsche, BMW, Tesla
I can't believe this is such a common issue. You'd think Mercedes would get this right by now. I had this exact issue on my 2007 S550 and it drove me nuts. S-Classes should get this right.
Old Feb 27, 2023 | 01:28 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
The pricing seems completely wrong on this?
They are likely not quoting the solution per TSB
Removing the seat back is done with seat in car and takes 30 minutes to r&r.
I doubt they are then going to spend 20 hours applying felt.
Old Feb 27, 2023 | 04:53 PM
SW20S's Avatar
2024 S580
Correct, it was not a big deal at all when they did it on my car. 33k miles later and the noises are totally gone
Old Feb 27, 2023 | 07:42 PM
badq45t's Avatar
2016 S550e, 2005 Nissan Xterra 4x4, 1984 300ZX
Call 800 and see about good will, if not take to an uphostery place they do this tpe of stuff all the time I bet it is a minor repair for them.
Old Feb 27, 2023 | 11:28 PM
NJ560's Avatar
2019 S560
Calling tomorrow… let’s see what they say.
If this was a $400 repair I wouldn’t even care. The labor on the quote seemed absurd.
Old Feb 28, 2023 | 03:51 PM
badq45t's Avatar
I bet that an uphostery shop this is less than that! Update I am curious what MB says
Old Mar 1, 2023 | 09:28 PM
NJ560's Avatar
2019 S560
Going to give them a buzz tomorrow… finally will have a moment. I’ll update the group on the outcome.
Old Mar 9, 2023 | 04:41 PM
Nico9182349's Avatar
W222 S560 4matic 2018 and C140 CL 500 1998
Just mentioning this because I had a seemingly creeping seat myself - for me it was my belt buckle rubbing up against the leather on the center console. I attached some adhesive fleece and that got rid of it. It sounds like you have some worse issue though. I did genuinely think something was wrong with the seat initially.
Old Oct 13, 2023 | 04:26 PM
Burkekernen's Avatar
2003 SL55 AMG
I've isolated mine to the seat belt retractor. SL55 AMG. I'll post again when I find the problem in there.
Old Oct 14, 2023 | 09:43 AM
NJ560's Avatar
2019 S560
Mine is definitely in the seat. Shifted around in it without the seat belt. I have noticed that adjusting the back of the power seat makes it go away for awhile.
I have the TSB, one day when I have time I’ll take the back of the seat off any apply felt to the innards.
Old Oct 14, 2023 | 02:27 PM
2003 SL55 AMG
I got the back off and mine already had felt every where. So some one before me had the tsb done. I tried taking the front leather off to get the tensioner out but gave up. I lubed the crap out of it where I could. But to no avail. It is worn internally at one spot (right where the belt normally rides). You can feel a slight grinding. If I could lengthen or shorten the belt to ride in a different position or might work but so far, complete failure.
