S-Class (W222) 2014-2020
Engine Mount
Old Oct 20, 2023 | 11:53 AM
Denis Osullivan's Avatar
2018 s560v4
Engine Mount
Has anyone had their engine mount replaced on a S560? Price and labor? I’m reading that it is a 23 hour labor
My car is 2018 with less than 50k.
Old Oct 20, 2023 | 03:34 PM
waterzap99's Avatar
S550 V8, CL600 V12, SLK32 AMG
I have not done it, but got prices from $1000 to $2000. The $2000 is with OEM mounts from a shop that only does Mercedes. Will go there eventually.
Mine is is only RWD though. AWD cars would be more.
Old Oct 20, 2023 | 05:58 PM
vinflouen's Avatar
2019 W222 S560 4Matic/2025 Yukon Denali
I have a 19 with 66k on it.
ive read its a large job.
Old Oct 21, 2023 | 05:12 AM
George A.'s Avatar
Mercedes S550
I have a 2015 S550. Just replaced the two engine mounts and the transmission mount. Bought the three components (2 slightly used. one new) on eBay, and had them installed at my local Pep Boys, via their Mercedes expert. Whole thing, parts and labor cost a total of $1300. Took about 6 hours to complete.
Hope that helps.
Old Oct 21, 2023 | 09:57 AM
blackbullit's Avatar
2013 ML350, 2019 S560
I am curious to know what kind of issues led to conclusion that engine mounts were worn out.
Old Oct 22, 2023 | 03:41 AM
BenzV12's Avatar
W212 FL
I think it's about material quality or planned maintenance items just like any other rubber components . I also believe that driving or abusing the car also should be one of the main factors for being them kaput . Just think about the force you put thru the throttle when you launch the car . Enormous amount of torque puts many stress on many components and engine or tranny mounts are one of those components as well . They have to handle such mindblowing torque .
However careful you drive or baby the car , those components need to be replaced when they're due as well.
Old Oct 22, 2023 | 06:02 AM
George A.'s Avatar
Mercedes S550
On my 2015 s550, I went to the dealer on a sunroof issue, and they went over the vehicle to check everything. They came up with the engine mounts, transmission mounts and a leaky coolant bottle. I bought all of the components on eBay, and had them installed at Pep Boys. All worked great.
I had some clunking, when I went over bumps. That was the only sign that something was wrong. All better now.
Old Oct 22, 2023 | 10:19 PM
mercedesbuff's Avatar
'20 GLS450, '17 S550 Sedan
Failed Motor Mounts -- How Can You Tell?
I've dealt with failed engine mounts three times. Once on a W212 (E550), and twice on the same W166 (ML550). Both vehicles had the M278 engine... not sure if that one is more prone to premature failure. Haven't dealt with it yet on my W222.
In any case, the three main symptoms were always the same.
1- No longer smooth at idle. Almost felt like the engine was misfiring. In fact, the first time it happened, when I stopped at a red light and immediately noticed the rough idle, I instinctively looked down expecting to find the "Check Engine" light illuminated, since it felt exactly like an engine misfire.
2- No longer a smooth engine startup. Instead, every time the engine was started, I could feel the engine "bottoming out" (for lack of a better term) on the frame, since there was no longer a functioning engine mount there to cushion it.
3- When driving over even moderate bumps, the engine would again feel like it was "bottoming out" on the frame, which meant that the front end of the vehicle was very busy, up and down, on all but the smoothest roads. Aside from being annoying, this also occasionally lead to a feeling of serious instability, especially at freeway speeds. Generally, the front of the car felt like it was no longer "tied down."
Hope this helps!
Old Oct 22, 2023 | 10:44 PM
2012 merc amg's Avatar
2018 S560
I hope to go over 100K miles before I worry about these mounts, my 2018 is up to 66K miles now and it's mostly highway so hopefully that'll help out.
Old Oct 23, 2023 | 12:43 AM
BenzV12's Avatar
W212 FL
Hope this helps!
Besides, I felt vibrations on the brake pedal when shifting out of P and generally vibrations during idling when those components were worn out . I also heard a weird noise when the engine was running must same as yours no smooth engine idle .
Old Oct 23, 2023 | 09:06 AM
2018 s560v4
Thanks for the feedback.
It seems that my issue isn’t a mount based upon others experiences.
I feel a vibration only on the steering wheel only at idle. It’s like a buzzing electric razor feel. It comes and goes meaning I don’t feel it on some days verses the next day.
Old Oct 23, 2023 | 07:11 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
4 Matic? Its normal.
Old Oct 23, 2023 | 07:42 PM
2018 s560v4
[QUOTE=SW20S;8865740]4 Matic? It’s normal.[/QUOTEIt is 4matic. Why is that a normal? What’s causing this vibration?
Old Oct 23, 2023 | 08:00 PM
as.thompson's Avatar
Veteran: Air Force
S550C4, Porsche Cayenne
I don't feel anything like that with my S550 C4 coupe.
Old Oct 23, 2023 | 09:15 PM
SW20S's Avatar
2024 S580
If you do some searching on the forum you’ll see posts about it. Many 4Matic 560 cars develop a vibration at idle, does it go away when you put it in neutral?
I had the dealer and my independent mechanic thoroughly check the motor mounts and they are fine, both confirmed that this happens with many cars.
Old Oct 26, 2023 | 01:56 PM
MBNUT1's Avatar
2010 E350 4Matic
Review this thread
https://mbworld.org/forums/s-class-w...bration-4.html
Old Oct 26, 2023 | 03:19 PM
2018 s560v4
Originally Posted by MBNUT1
My Eco/start has been programmed off via Benzninja for months
Old Oct 26, 2023 | 03:21 PM
SW20S's Avatar
2024 S580
So has mine, vibration is still there.
Old Oct 26, 2023 | 03:31 PM
ajm0623's Avatar
'25 740i; '15 targa4s; '24 cayenne
i have no vibration whatsoever. 2020 s560 4m. 25,000mi
Old Oct 26, 2023 | 03:51 PM
SW20S's Avatar
2024 S580
Mine didn't develop until after 30,000 miles.
Old Oct 26, 2023 | 04:07 PM
tx170754's Avatar
S560/SL550/LS460/Q70L 5.6 AWD
So, totally confused, the vibration wasn't there until 30,000 miles but it is there after and the dealer and "some" mechanics are saying that the is normal?
It came from where ?
Old Oct 26, 2023 | 04:29 PM
SW20S's Avatar
2024 S580
Theres clearly something that causes it, but it’s not something that’s easily diagnosable or easily repairable is the point. It’s not motor or transmission mounts…and it seems to only occur in 4Matic cars.
Old Oct 31, 2024 | 09:10 AM
Pamaz@0152's Avatar
S560
Angry S560 4matic Thermostat recall/campaign
I took my 2020 S560 to the dealership to have thermostat recall completed. After getting the car back I felt a thud under acceleration. I took it back and the tech said the driver side engine mount was broken. I looked at it and it was certainly broken. Hard to believe the mount broke on a 2020 with less than 50K miles. I think the mount was removed to facilitate other maintenance and was never replaced properly.
Old Oct 31, 2024 | 11:13 AM
SW20S's Avatar
2024 S580
That thermostat job is a HUGE job, absolutely they could have broken the mount.
Old Oct 31, 2024 | 03:46 PM
MBNUT1's Avatar
2010 E350 4Matic
Seriously? Replacing the thermostat on an S560 is a huge job that requires undoing motor mounts? Reminds me of a friend of mine who's thermostat on his GM truck went out on the way to Yellowstone and it was a two day affair to replace and him wondering what genius thought that was good idea?
