S-Class (W222) 2014-2020
New tires
Old Aug 10, 2023 | 06:00 PM
JasonHedrick's Avatar
2017 S550
New tires
FYI, just had 4 Pirelli P-zero run flats installed for around $2200. We will see how they hold up
Old Aug 10, 2023 | 08:30 PM
blackbullit's Avatar
2013 ML350, 2019 S560
I like mine. They last about 12-14k miles. Expensive but worth it.
Old Aug 11, 2023 | 04:20 PM
2017 S550
Thanks, good to know.
Old Aug 12, 2023 | 12:28 AM
BenzV12's Avatar
W212 FL
I have heard good things about it but I have not used them as I am a Michelin fan
Old Aug 12, 2023 | 10:04 AM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
I have the same tires but non run flat. Why did you stick to run flats?
Old Aug 12, 2023 | 12:25 PM
Quenthel's Avatar
S560 Long 4Matic (DE) MY 2018
In July I had a small accident and ripped one of my rear tyres (roadworks with sharp freshly cut asphalt), an Eagle F1 Asymmetric 2 MOE, that is, runflat.
I replaced them with one of the P-Zero variants and the difference in quietness and comfort is incredible.
Same here.
Old Aug 12, 2023 | 12:55 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
I had those Goodyar Eagle F1's on my car as well, and the ride was terrible. I didn't replace with RFT's, just regular tires. But I think anything would have been an improvement offer the Goodyear F1 MOE tires. Let us know how the Pirelli RFT's wear and feel long term.
Old Aug 12, 2023 | 07:28 PM
2017 S550
Plan on some long trips and don't like the idea of no spare tire
Old Aug 13, 2023 | 11:23 AM
SW20S's Avatar
2024 S580
Run flats won't help you much from not having a spare tire...see my thoughts on it from this other thread:
This is a mental thing.
The reality is runflats will only help you in the event of a puncture, which is never going to leave you stranded anyways. Punctures can be patched at the roadside or a gas station. All the runflat does is get you from the roadside to a safe spot or a gas station. I have maybe had 3 flat tires in 25 years of driving, and I have spent many of those years driving 25,000+ miles a year. Of those 3 flat tires I have only had to put the spare on one time, the other two times roadside assistance plugged the tire at the roadside. The time I had to put the spare on was a total sidewall rupture, which would have also rendered a runflat useless.
So, without a spare the one time I needed a spare I would have been just as stranded on the roadside if I had runflats.
The slime/inflator kits will get you moving and to a safe place to have the tire patched if getting it done at the roadside is impossible. But, with a patch kit you can easily plug a tire yourself.
I don't have a spare in either the S560 or our Pacifica. The Pacifica never had runflats, it just has no spare. The S560 I replaced the runflats and bought a inflator/slime pump and a patch kit. I drive it on rural road trips with total confidence. If you need a tire out in the middle of nowhere, you're gonna be stuck a couple days unless you have a full sized spare which few cars have anymore. A temporary spare will only again get you to safety.
This is the pump/slime kit I have:
https://www.griotsgarage.com/12v-tir...SABEgJNZPD_BwE
And the patch kit:
https://www.harborfreight.com/heavy-...iABEgLRlvD_BwE
The Pacifica came with an inflator/slime unit but I also bought the patch kit for it too. If I ever got a nail or something, I would just patch it myself, the difficulty is doing that without being able to take the tire off the car...
Old Aug 13, 2023 | 01:09 PM
2017 S550
Thanks for your opinion. I want to be able to get off the interstate to the nearest exit, be it 1 or 50 miles away. Then find a safe place to determine whether I have a tire that may be able to be repaired.
I have been looking at the Mercedes Tirefit as well.
Old Aug 13, 2023 | 05:56 PM
SW20S's Avatar
2024 S580
You may or may not be able to do that with a runflat is the point. A flat on the interstate is typically not from a slow leak, its a larger issue often a sidewall issue and a runflat isn't going to help you there. I just don't see the point in the expense or reduction in performance of runflats when its such a rare scenario when you actually need them. The car rides like a different car without the runflats.
If you want a spare, you really should just get a spare, runflats are not a replacement for a spare
Old Aug 13, 2023 | 06:45 PM
2017 S550
I get it, you don't see value in run flat tires. I do. Agree to disagree.
Old Aug 13, 2023 | 09:34 PM
2012 merc amg's Avatar
2018 S560
I see no reason myself to switch from the tires that were put on my car at 16K miles when I bought the car. They are Continental Pro Contact GX run flat tires. They ride fine and the car handles great. At 62K miles now the fronts appear to a little more than halfway worn although the mileage I'm getting out of the rears is significantly worse, I replaced them after 25K miles and may need to replace the current ones within 10K miles or so, my car is RWD and a lot of power going to those rear wheels so the rear tires wear at more the twice as fast as the fronts.
Old Aug 14, 2023 | 09:45 AM
SW20S's Avatar
2024 S580
Thing is you don't yet know how much better the non run flat tires make the car. If you did, you wouldn't want to go back. I had the same tires you did, and they are "fine" but when replaced with good non run flat UHP tires the car rides and drives like it truly is supposed to.
Old Aug 14, 2023 | 08:58 PM
2018 S560
Well maybe you’re right. On the highway the car rides amazing. Around town the local roads are kinda choppy and you feel those potholes a lot. Maybe I will try a non run flat when I replace all 4 in about a year.
Old Aug 14, 2023 | 09:02 PM
2018 S560
it did save me with my wagon a year ago or so. Got a rod that went into the tire. I drove the run flat with no air it back to the dealer 30 miles away. The tire was toast but at least it got me there.
Old Aug 15, 2023 | 11:06 AM
SW20S's Avatar
2024 S580
The difference in that around town ride will be significant.
The question is how much reduction in performance are you willing to accept for the potential that you might be saved in that sort of situation? How many times in your driving life has something like that happened to you? Its a pretty rare occurrence not only that you would have a significant hole in a tire that couldn't be sealed and inflated with the car's pump, but that also wouldn't have been in a place on the runflat where it wouldn't have kept the runflat from being functional.
Old Aug 22, 2023 | 05:32 PM
GABenz550's Avatar
S-550
The Pirelli P-Zero RF were on the car when I bought it. They look good, not sure how well they will wear and thought is a non-run flat tire might be quieter.
Old Aug 23, 2023 | 09:02 PM
BeanBR's Avatar
2018 S 450
True. Hit a pothole at 80mph on i95 and my run flat P Zero was flat in a fraction of a second. Car was immediately undrivable.
Old Aug 24, 2023 | 11:28 AM
waterzap99's Avatar
S550 V8, CL600 V12, SLK32 AMG
Have a set of 20" P Zeros in classifieds if anyone is interested.
Old Sep 25, 2023 | 09:00 PM
S_W222's Avatar
Current/Last 5-years:GLS;G70;Alpina B8;X7;Accord. Sold:X7,TeslaS;S560;S550,X5;530e;L.Navigator;LS460
If you read through historical forum threads for these tires sizes (whether it's for the W222 or another Mbenz or even another brand), you will ALWAYS find good reviews for two specific options that I am yet to see anyone reporting any issues with unlike other options; those are:
1. Pirelli Pzero All Season Plus; and 2. Continental Extremecontact DWS06+.
I went with Continental Extremecontact DWS06+ for the W222, and also read excellent reviews and test-results about the Pirelli's ones. I would not consider any other tire outside those two (unless there is a reputable one with foam "sound insulation" that other's have tried for the W222. Based on photos, I like the side geometry of the Pirelli (they look nicer when cleaned), but I feel the Continental is the softer and more quite option based on reviews. I would go with Continental again, but would also take the Pirelli's if the Continental aren't available. Price is relatively similar for both (~1100-1500 depending on where you get them from, and sale events)
Old Sep 25, 2023 | 10:04 PM
SW20S's Avatar
2024 S580
Yep, I think its hard to go wrong with either of those tires.
Old Sep 26, 2023 | 10:27 AM
GABenz550's Avatar
S-550
Great, thank you for your insight. I will be getting the new tires in a couple weeks.
Old Sep 26, 2023 | 11:24 AM
Qflight's Avatar
S560 4Matic
Any thoughts on Costco options that are not run-flat?
Old Sep 26, 2023 | 02:47 PM
SW20S's Avatar
2024 S580
I don't think they sell any tires that I would choose
