S-Class (W222) 2014-2020
Broken E10 bolt used to hold front break pad sensor
Old Nov 29, 2023 | 08:43 PM
Bigbodybob's Avatar
2014 Mercedes S550
Did something stupid and broke the E10 torx bolt that hold the brake pad sensor near the caliper. Where can I find a replacement bolt? I'm not sure if it has specific specs or if I should just measure it and try to find a comparable bolt at the hardware store.
Old Nov 29, 2023 | 10:16 PM
95Sinned420's Avatar
2016 S550
If not from the dealer, not sure where you'll find one since its not so generic? Find something similar I suppose. Its not a crucial bolt that does anything special... just holds a wire in place.
Old Nov 30, 2023 | 07:08 AM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
Aside from the bolt head all the fasteners are metric and shown in the parts catalog. For the front wear sensor, it looks like this is the correct bolt.
N 910143 006002
HEXALOBULAR BOLT
FASTENING, WIRING HARNESS AT BRAKE CALIPER,RIGHT; M6X20
The part numer is at the top in case you want to get one at the dealer, N 910143 006002. The bolt is an M6, 20mm long.
Old Nov 30, 2023 | 11:15 AM
Bigbodybob's Avatar
2014 Mercedes S550
Thank you both so much
