S-Class (W222) 2014-2020
Dash Flickering
Old Jan 5, 2024 | 02:13 PM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Dash Flickering
Did some searching - cant find anything too awful similar ....anyone know a solution to this intermittent issue?
Old Jan 5, 2024 | 02:25 PM
DaveW68's Avatar
Veteran: Army
2015 S550
Looks like a loose wire or faulty circuit.
Old Jan 5, 2024 | 03:15 PM
I agree, just thinking I am not the first person so have this....
Old Jan 6, 2024 | 02:32 AM
BenzV12's Avatar
W212 FL
My bet is on the battery
Old Jan 6, 2024 | 04:56 AM
Which one?
Old Jan 6, 2024 | 05:25 AM
GreasedFolgore's Avatar
2025 Maserati Grecale Folgore and 2024 Jaguar F-PACE SVR
Does it do it when car isn't running? Doesn't seem like enough vibration to make power flicker like that and I'd expect some other visual glitches from data getting corrupted if a connector was that loose. Kind of reminds me of an LED light bulb going out. That little center display is backlit with an LED I believe.
Old Jan 6, 2024 | 07:46 AM
Yep...that's running. Very random over the past year. Not temp dependant either....
Old Jan 6, 2024 | 08:24 AM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
You might find more information on this issue on the GLS forum as the dash as the W222 dash is the first to be all digital. From your video it looks like there's a broken board trace or wire somewhere, were it a larger problem like a battery being defunct it would likely affect other systems as well.
Are you able to scan with Mercedes Diags for any clues?
Old Jan 6, 2024 | 08:37 AM
Clean scan.... I had it on the GLS about six months ago...No answers (or replies). Figured would be the same in the S? Guess not.
Old Jan 6, 2024 | 09:00 AM
dlafever's Avatar
Not so much, we're all glass here.
Well shoot. There's not a lot of info online either (which I'm sure you know.) In the past few decades of working in IT, that kind of wonky LCD flutter is usually a reason to replace the display.
It seems that there are some solutions for this if you're interested. This is just an example I have no affiliation with this site.
https://store.minitools.com/en/sei-d...-clusters.html
Old Jan 6, 2024 | 09:52 AM
Yeah....I have the skills, the tools....it is the desire to rip the entire freaking dash apart that I struggle with.....I admit it, I am looking for a simple solution (Heh, I am modern 'merican). Wait, the S did have this same dash, this car is a 2017 (I think, I refer to it as "The Blue Car"). My E63's do not have color in the center display like this one does.
