S-Class (W222) 2014-2020
Burned valve
Old Jan 14, 2024 | 08:02 AM
Sm516's Avatar
2007 mercedes s550
Burned valve
Can anyone tell me if i have a burned valve
thanx
Old Jan 14, 2024 | 11:14 AM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
Why do you think you have a burnt valve. Looks like normal carbon deposits to me. Is compression low?
Old Jan 14, 2024 | 12:11 PM
kafklatsch's Avatar
All Cars Lost To Hurricane Isaac (W124 E420 revived - added 88 Allante 14 S550, 17 S63
Yeah ...What he said..
.........looks normal... any issues?
Old Jan 14, 2024 | 01:49 PM
Sm516's Avatar
2007 mercedes s550
I dont know if it has low compression but its Misfiring after an oil change and throws a code p0308 and p0300 thax for Replying
Old Jan 14, 2024 | 04:21 PM
MBNUT1's Avatar
2010 E350 4Matic
Please keep us informed of your findings. Would suggest a compression test.
Old Jan 14, 2024 | 07:22 PM
superpop's Avatar
Swap coils around and see if the code follows the coil. Also check the plugs.
Old Jan 15, 2024 | 12:02 AM
JohnLane's Avatar
222 S-65
Burned valve easier to diagnose with a leak down test than via photos of pistons that look utterly normal.
As mentioned above start with re-arranging ignition coils and see if the misfire follows the coil.
