S-Class (W222) 2014-2020
M176 reliability?
Old Jan 28, 2025 | 07:33 PM
legegendary91's Avatar
S 560 4 Matic and 2024 AMG S63E
Originally Posted by SW20S
To be clear I am not the person who gave a 150k mileage mark, that was chassis and I think thats absurd.
yes, sorry, thank you for pointing this out
Old Aug 19, 2025 | 06:32 PM
vetal's Avatar
2004 Sprinter
M278 and M176
Hello guys,
I am new to the forum. I did read the forum a lot, but wanted to get advice from members who work on their W222.
I am not a mechanic, but pretty handy, had a 1999 LS400 years ago and maintained it myself for 300K miles. I did all fluids, engine, transmission, steering, coolant, diff, fuel filter, spark plugs, radiator and coolant hoses, power steering pump rebuild, drive belt components and belt, alternator, engine and transmission mounts, starter ( inside engine V under manifold), multiple brake and suspension jobs, upper and lower control arms, struts, all sorts of bushings, wheel bearings, driveshaft flex discs, etc.
I have an old Sprinter with 414K miles and I work on it myself, almost exclusively, it’s my work van.
I am considering 2015-2017 S550 4matic ( I live in the Rockies) with 60-70K miles, maybe less.
1.Would you say stay away from 2014 for sure, or have it bore-scoped? I see one with 116K miles and highly optioned.
2. Do I really have to bore-scope 2015-16 models?
3. Should I consider 2018 S560 if I can swing it?
Which car is more DIY-friendly, M278 or M176?
These sedans are not popular in my area and I would have to buy out-of-state, going to order an inspection by a third party prior flying/driving to look at it myself. Logistics could be tricky though…
I would want to keep W222 for a while and maintain it myself whenever possible.
Any thoughts are welcome and appreciated!
Old Aug 19, 2025 | 07:30 PM
Donnymac's Avatar
63 Falcon vert
2017 is a great car. I'm at 82,000 miles all hwy.
Change oil at 5000 and performs like new. Repairs have been wearables and a few sensor bugs.
Check the maintenance history and do your homework.
Good luck with the search.
Old Aug 19, 2025 | 07:34 PM
Originally Posted by vetal
Hello guys,
Do you have time for a phone call? It would be easier to share it by speaking.
otherwise, I can fill you with some crucial keys in here.
I only work on my 2018 S 560 4Matic ( dealer never touched it basically) and am almost at 490,000 miles.
i had same Lexus you mentioned as well.
Old Aug 19, 2025 | 08:31 PM
vetal's Avatar
2004 Sprinter
Val
970-948-5839
Thank you
Old Aug 19, 2025 | 08:40 PM
chassis's Avatar
2017 GLE350 4MATIC
Is it correct, 490,000 miles on a 2018 S560?
Old Aug 19, 2025 | 08:41 PM
  #32
MBNUT1's Avatar
2010 E350 4Matic
I would only look at 2016's or later unless you get the motors serial number to avoid risk of the bore scoring. M176 valve cover leaks would be a big challenge for a DIY guy.
Old Aug 19, 2025 | 08:52 PM
  #33
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Exactly. Latest from Tassos
Old Aug 21, 2025 | 02:14 AM
  #34
antica's Avatar
This is a good question. Would like to hear from any S560 owners that have high miles. I am thinking that the M176 is a better engine than the M278 only because of the issues identified with the M278 and lack there of with the M176, but that could simply be because the M176's haven't had enought miles on them yet.
I have a 2019 S560 4MATIC with just under 180k miles. Other than regular maintenance the only major work I have needed to do is the engine mounts and the valve cover gasket which both was recently (less than 10k miles ago). Other than that car has been a fun and super reliable luxury ride!
Old Mar 21, 2026 | 09:07 PM
  #35
nobert79's Avatar
19' E450 4matic
I'm also curious on this as well. Currenly running a 19' W213 E450 4matic, bought almost new, 4k km on odometer, and after almost 6 years, it's got 175K km now. Everything still run great. Just found a low mileage 19" W222 S560 4 matic at a very attractive pricining. Good idea?
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
You have already rated this thread Rating: Thread Rating: 1 votes, 3.00 average.
