S-Class (W222) 2014-2020
ILS Question
Old Feb 4, 2024 | 03:13 PM
ElastomerGuy's Avatar
2017 AMG S65 Cab 2024 S63 AMG e Performance
ILS Question
I've got a 2019 S65 AMG. I had BenzNinja implement ILS on it a few weeks ago. I've driven the car a few times at night and despite all that I've read, ILS not been too impressive. With the lights in auto, it does not appear to properly adjust to prevent the high beams from blinding oncoming traffic. Frequently, oncoming cars will flash their bright lights or flash and then just leave their bright lights on. So, I'm sure the lights are bothering oncoming cars. Am I doing something wrong? Do I need to turn ILS on somewhere after it's been implemented? Thanks in advance for any help that can be offered.
Old Feb 4, 2024 | 03:52 PM
Jim Ma's Avatar
S 550, S65 Coupe
I had to activate it in the Lighting menu after BenzNinja coded it for me. My car is a bit older, 2015, but i would check you lighting menu and see if it is activated.
Old Feb 4, 2024 | 04:58 PM
BenzNinja's Avatar
Former Vendor
feel free to whatsapp
Old Feb 4, 2024 | 07:44 PM
vincheung's Avatar
S63, GLE580, BV250
Double check in the settings menu that ILS+ is turned on. The coding provides the option to switch it on/off, you still have to manually activate it for the first time and you are good to go.
Old Feb 5, 2024 | 06:06 PM
Mitch Alsup's Avatar
Top Answer: 1
S600
ILS == Instrument Landing System ?!? (since the middle 1940s)
How high up in the air is your car going ??
Old Mar 20, 2024 | 02:18 PM
W205C43PFL's Avatar
ILS in MB terms stands for Intelligent Light System.
Old Mar 20, 2024 | 03:19 PM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
I had ILS+ enabled a couple of months ago (although not by BenzNinja), and have never had anyone flash me since enabling the system.
It is quite apparent when the system 'blocks out' a box around either oncoming or same-direction cars, while leaving the high-beams enabled to either side.
I believe I recall someone else had a similar situation, and the cause was mis-aiming of the headlights themselves (rather than a malfunction of the ILS system).
While I don't know the correct method for verifying the headlight aim, maybe one of the other members here can help out with that matter.
Old Mar 20, 2024 | 03:34 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
I hope the OP got it figured out. I had that happen when I had the bright lights turned on, instead of pushing the stalk forward to engage ILS. That sounds like what's happening, because the unlit areas are easy to identify when ILS is working, even without the ILS+ functionality.
Old Mar 20, 2024 | 06:48 PM
JohnLane's Avatar
222 S-65
ILS is all that. Has to be enabled and headlights left in ‘brights’ position. With all this done an indicator in the cluster will indicate that lights are set to auto. Great for long winter nights.
Old Mar 20, 2024 | 08:32 PM
BenzNinja's Avatar
Former Vendor
also misalignment. many don't notice misaligned lights when they don't have the ILS+
once ILS+ is activated you get this:
Old Apr 13, 2024 | 11:23 AM
BeanBR's Avatar
2018 S 450
Same thing here. Had it done a while ago but didn't really notice any difference. The blue high beam indicator light apparently stays on more frequently but as far as seeing blocked out areas from the beam, that has never happened.
Old Apr 13, 2024 | 11:40 AM
vincheung's Avatar
S63, GLE580, BV250
Bean, has the intelligent lighting option been toggled on via the wheel menu/dash menu selection?
Old Apr 13, 2024 | 12:22 PM
BeanBR's Avatar
2018 S 450
Yes, I toggle it on and of during drives and road trips but can’t really tell any difference.
The only thing that MAYBE has changed is that the high beams don’t turn on as much, which is actually worse than the original programming. And when this happens, the high beams will turn off but the indicator light will remain on.
Having people flash me the high beams has never been a problem. The auto function in it’s factory programming works for me. I was looking for the ability to actually block out areas and have everything else illuminated. That never happened
Old Apr 13, 2024 | 03:11 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
Have BN go in and check it, somethings not right
Old Apr 14, 2024 | 04:33 PM
kafklatsch's Avatar
All Cars Lost To Hurricane Isaac (W124 E420 revived - added 88 Allante 14 S550, 17 S63
Just last night i encountered a silly situation where the 2 lanes instantly shifted by a half lane... the lane markings and all... from an old road to a brand new repave. My ILS lights danced around ahead of me and intensified the crazy lane shift area, and changed the beam trajectory over to the new lanes.... all before I reached the juncture... its pretty amazing to see the lights take on a life of their own... figuring out things ahead, for my safety
Dont quite understand why the old/new road marking and lanes dont "transition' but literally jump.... discussion for another forum i guess..
Old Apr 14, 2024 | 05:26 PM
SW20S's Avatar
2024 S580
It’s amazing. Why it has been illegal here is beyond me!
Old Apr 14, 2024 | 06:17 PM
Top Answer: 1
S600
When a cars light change direction an oncoming driver may think the car is moving (not just the lights).
Old Apr 14, 2024 | 11:35 PM
SW20S's Avatar
2024 S580
Not buying that…the lights don’t move, they just illuminate certain LEDs in the matrix and shut off others. Swiveling headlights have always been allowed in the US.
These have been illegal because of a technicality in the law
Old Apr 14, 2024 | 11:44 PM
JohnLane's Avatar
222 S-65
Hmmmm..... Our overlords at .fed and too many states are mandating we all purchase electric cars and that is just a fine....
It has only been in the last YEAR the idiots have relented and allowed we; the unwashed to have intelligent lighting that really IS an improvement over ‘auto dimming lights’ and the rest of the trash Detroit and the rest of the world puts forth which is supposed to pass as reasonable and safe lighting. I’m sure we have all noticed how current LED headlights coming at us are akin driving into the sun after coming out of a dark tunnel in the middle of the day!
If our dear friends in government gave a damn Intelligent lighting would be required for all cars. I have had my wife drive toward me in my 222 S-65 as I drive her Toyota..... It doesn’t blind me. Virtually every other LED equipped car has me reaching for the sunglasses at night.
/rant
Old Apr 15, 2024 | 12:11 AM
kafklatsch's Avatar
this may be only partially true, for the "S" preface-lift ILS, they do actually move within the housing, I think the matrix lights may have come facelift and all ILS afterwards..
I have watched my led lens move within the housing.
someone may be more definitive and correct me, but a video of a moving ILS LED is here
Old Apr 15, 2024 | 01:04 AM
JohnLane's Avatar
222 S-65
The HID lenses in my 2004 E-500 moved to point into turns. Great system that is worlds away from ILS that allows it to keep high beams on while making a box of darkness for oncoming vehicles and cars in front of you while lighting up both sides of the road, overhead signs and illuminating pedestrians, cyclists, critters etc.
I enjoy watching the system pick what gets lit up and enjoy not overdriving the headlights or getting flashed by oncoming traffic.
Old Apr 15, 2024 | 09:07 AM
SW20S's Avatar
2024 S580
The lights in my LS460s and my GS350 moved left to right also, that’s not the reason these were illegal.
Old Apr 15, 2024 | 11:35 AM
S_W222's Avatar
Current/Last 5-years:GLS;G70;Alpina B8;X7;Accord. Sold:X7,TeslaS;S560;S550,X5;530e;L.Navigator;LS460
That's true. Until 2022, the US safety regulations did not even allow for any any kind of adaptive headlight technologies at all.... Light beams hovering around other vehicles simply wasn’t something allowed no mater what so the technology wasn’t allowed here by default even when it's safe, unlike Europe which had some standards for adaptive headlights. After so many years, US regulations for adaptive beam headlights were finally developed but even until now it looks like the requirements so difficult to meet that automakers still could not offer it yet even for newer cars. It's unfortunate, but am sure someone will figure it out soon, unless there is really no way around the current strict regulations that makes adaptive headlights useless.
