S-Class (W222) 2014-2020
2015 s550 problems, is the dealership taking advantage of me?
Old Feb 19, 2024 | 06:40 PM
jut702's Avatar
15 edition 1 s550 4 matic coupe, 08 Chevy duramax 2500hd 34k mi, 87 ford bronco 2 32k mi, 72 pantera
Hey guys, about 4 months ago I purchased a 2015 s550 4matic edition 1 it was used with one owner who was an old lady who used it for business purposes. we bought it with 40k miles and put about 10k miles into it so far. Absolutely love the car. Luckily we bought an extended comprehensive warranty with the vehicle from Toyota. (since it we bought it from them). So the service a4 came on, time to take it into the shop. I was quoted almost 12k in labor and work. fault codes p035313, p030385, p030085. replace cylinder 3 ignition coil. $590. front cylinder head covers are starting to leak. reseal front cylinder head covers $1730. transmission/differential/ transfer case, front diff pinion house seal is leaking. remove trans and front diff, replace seal and hardware $3800. alignment $300. engine mounts are collapsed and weak $4500. spark plugs are due $1050. transmission service $600. Im located in Las Vegas. Its a lot of money to put into this car just to get it running, any help or suggestions would be much appreciated. Thank you guys.
Old Feb 19, 2024 | 06:52 PM
superswiss's Avatar
2019 C63CS
Well, sounds like quite a battered car. From your fault codes, your engine is misfiring. You didn't notice it was running rough or the CEL flashing? This could have caused your engine mounts to fail prematurely due to the additional vibration. It's specifically reporting an issue with the ignition coil circuit in addition to misfiring on cylinder 3. So that is what it is. The various leaks and collapsed engine mounts if true is also what it is. Those are big jobs. Leaks do happen and engine mounts can also wear out eventually, so not sure what to tell you there. Spark plugs is routine and technically due every 50k miles or 5 years. Not sure about the transmission service. I thought only AMGs require transmission service. Alignment is also pretty standard. That and spark plugs is about the only thing I have a reference for in terms of price. It seems a little high. Alignment on my AMG is only about $200. Don't know what the spark plugs by itself cost, but my most recent 5 year service would have been about $1700 for my AMG including spark plugs. Next one includes my transmission and rear diff and is also around that. I ended up prepaying for the next three services, which was cheaper than paying for the individual services and it locks in today's labor rates. If I sell the car before the end of the prepaid maintenance, here in California they have to refund the unused portion, so it's a win-win.
Old Feb 19, 2024 | 07:11 PM
jut702's Avatar
Never noticed anything running rough nor the cel flash. The engine started to sputter and loose power maybe 3 days ago. Today I drove it to the dealership and it drove like it always has when i first bought it. I do not drive it like a teenager. i baby this thing. so hopefully my comprehensive warranty will take care of all the parts and i will only have to pay for labor is the best case scenario. Just sucks being such a old but new car having all these problems. thank you for the reply. Do you think toyota new about these problems before selling the vehicle to me?
Old Feb 19, 2024 | 07:13 PM
Highline-Autos.com's Avatar
SPONSOR
2001 E55AMG
Is this a dealership or independent? Take it for a second opinion. Did you notice anything wrong with it? That seems like an awful lot for you to be unaware of prior to diagnosis.
Old Feb 19, 2024 | 07:17 PM
jut702's Avatar
I brought it to a Mercedes dealership. fletcher jones in las Vegas. I noticed the check engine light came on 2 days ago. it started to sputter when I was going 10-30 miles an hour. Made an appointment right after that. Took it in today and the car drove like it always has.
Old Feb 19, 2024 | 07:19 PM
superswiss's Avatar
2019 C63CS
The Toyota dealership likely didn't know or care if any of these issues were present already. It's not their brand and the car is 9 years old. So that doesn't even qualify for Mercedes-Benz Certified Pre-Owned. Has to be less than 6 years old to get CPO. This is an old car by modern standards and sold as-is.
SPONSOR
2001 E55AMG
Just a heads up, the following are not considered maintenance and probably not covered by the extended warranty:
Ignition coil
Alignment
Spark plugs
Transmission service
(Engine mounts are 50/50, it really depends on how reputable the warranty company is)
Old Feb 19, 2024 | 07:20 PM
SPONSOR
2001 E55AMG
Plus 10K miles in 4 months is quite a bit.
Old Feb 19, 2024 | 07:31 PM
superswiss's Avatar
2019 C63CS
Yeah, there's that. That's way above average wear and tear. For future reference, a used car like this should be taken to a reputable independent mechanic for a thorough pre-purchase inspection before buying it.
Old Feb 19, 2024 | 07:39 PM
jut702's Avatar
I apologize, we bought the car with 45k miles its sitting around 52k, i just double checked. so about 7k miles in about 6 months.
Old Feb 19, 2024 | 07:40 PM
jut702's Avatar
Ignition coil
Alignment
Spark plugs
we do have a full comprehensive warranty from total care auto, everything listed is covered.
Old Feb 19, 2024 | 07:43 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
If the warranty is going to cover it all, let them do it all.
You should find a good, independent mechanic that specializes in Mercedes vehicles vs going to the dealer...
Old Feb 19, 2024 | 07:45 PM
jut702's Avatar
yes warranty should cover it all, but still with labor he said its going to be like a 40 hour job? looking at 4-6k in just labor.
Old Feb 19, 2024 | 07:47 PM
SW20S's Avatar
2024 S580
As long as you're not paying...having all of that stuff done benefits you whether it needs to be done or not.
Old Feb 19, 2024 | 07:55 PM
jut702's Avatar
does anybody have an idea how long this job should take? 40 hours seems like a lot. and what price are you guys paying for labor?
Old Feb 19, 2024 | 09:44 PM
superswiss's Avatar
2019 C63CS
They have book hours for these jobs, so that's what the estimate is based on. Actual repair may take more or less time depending on the mechanic or complications. If the book time says 40 hours, then that's the estimate you have to go on. Expect the car to be out for at least two weeks as they likely won't work on it continuously. Labor rates depend on your region.
Old Feb 19, 2024 | 10:51 PM
JDVIKING's Avatar
Slightly Modified E500, 2005 PT Cruiser
Wow, as I'm reading your post... An eerie feeling of deja came over me!
I'm a small mobile mechanic here in Las Vegas specializing in Mercedes, BMW etc and one of my customers had almost everything you've listed on his quote? (That's how he ended up becoming my customer LOL) I mean almost to the letter? So I went through the car for him saved him about $12,000 !! I believe his Bill was about $1800 That was for me to run diagnostics, fix everything that he DID need including, tune up new plugs , two coil packs, there was a bad coolant leak from the plastic coolant pipe against the firewall under the hood cowl. Some turbo coolant leaks as well ... I believe the steelership was in fact "Fletcher Jones" I still have the PDFs of the estimates that he sent me from FJ and they intended to just straight fix and replace parts that 100% did not need fixing moreover the prices were high for even a steelership but that's Las Vegas I guess... Your name wouldn't happen to be "X" and your S550 wouldn't happen to be black would it? LOL
Old Feb 19, 2024 | 11:46 PM
S_W222's Avatar
Current/Last 5-years:GLS;G70;Alpina B8;X7;Accord. Sold:X7,TeslaS;S560;S550,X5;530e;L.Navigator;LS460
I think it's just bad lack. It doesn't necessarily mean that the dealer took advantage of you. All these things could have developed just as you drove it for the last 1000 miles or so. 7K miles is a lot of miles to assume that some of these issues existed when u bought it.
Enjoy the car, if you are going to fix all these issues, and take care of that car going forward, sounds like u are about to renew/replace most of the high-ticket common wear&tear engine parts. Who knows, u might be able to drive it for 100K from here and pay $0 on service. My first W222 was a pre-facelift, and I drove it all the way to ~75-80K miles. I paid 0 (zero) on maintenance as I never needed any engine work (granted I sold it with lower control arms needing replacement). I only did some transmission service when it was under-warranty.
Old Feb 20, 2024 | 10:19 AM
JohnLane's Avatar
222 S-65
OP Fidelity with Platinum coverage will cover mounts, coils and countless other issues.
If your extended warranty covers what MB is suggesting pay the deductible and let them take care of it.
Old Feb 20, 2024 | 04:51 PM
roviw1's Avatar
2015 S500, 2016 GL63 AMG
One thing I would add would be that if you were having all the spark plugs changed then I would suggest the dealer could actually replace that coil pack in barely 10 minutes while doing the spark plugs, a replacement coil pack should be a lot less that 500$ , I did a search on you tube and found a video on changing them, I needed to do just one of mine 18 months ago, the coil packs at the time were scarce and MB UK had over 300 on back order, I found a good genuine merc one for about £60 online and did the job in about 40 minutes at most including removing all the plastic engine covers, I did also have to buy a special little unusual " E-torx " socket set from Amazon for about £10 to fit the fixing bolt holding the coil pack in place though
Old Feb 20, 2024 | 06:21 PM
SPONSOR
2001 E55AMG
Please update with how much your extended warranty is going to pay for the repair.
Old Feb 21, 2024 | 08:36 AM
300SE1993's Avatar
2012 S350 Bluetec, 2014 GLK250 Bluetec, 2026 E350 4Matic
Does your warranty not cover labor?
Old Feb 21, 2024 | 08:00 PM
jut702's Avatar
wow that is very interesting. would you mind sending me a dm and phone number and i will give you a call. i do have the comprehensive warranty from toyota does that cover all the parts from your shop or just the dealership?
yea thats what i was thinking, but after doing some research i can literally go sell this car right now and get my money back or make a little bit. its an edition 1 and after doing research i found s550s same year more milages for 40-47k.
that brings up another thing, why would they charge me all those hours for labor when the engine is already out. they are like doubling the hours of work when the engine is out. if that makes sense.
i definatly will they are going to give me a call tomorrow and i will update on how much it will cost and if i am even going to go with them to do the repairs.
no literally covers everything but labor
Old Feb 21, 2024 | 08:56 PM
SW20S's Avatar
2024 S580
If you’re paying for labor you should take it somewhere else and get a second opinion, an independent MB shop will be much cheaper. Labor rates at MB dealers are $200+ an hour.
2015 S550 with 55k miles is worth nowhere near $47,000 lol
Old Feb 21, 2024 | 09:10 PM
JohnLane's Avatar
222 S-65
OP I have worked with a LOT of extended warranties.... I’m in the auto repair biz. I have never encountered an extended warranty that does not pay for parts, labor and tax (less deductible) for covered parts.
