New Owner - Trunk Issue
The trunk pops open from the remote, door switch and trunk switch but will not fully open and has to be lifted open. Will not close with the buttons and both buttons are lit.
When I close it, it does fully latch on its own.
Checked fuses 401 and 491 and both are good. Trunk set to open fully on dash and valet switch in glove box set properly.
Where do I look next??
Thanks!
Activating/deactivating the trunk lid opening height restriction
Multimedia system/Vehicle /Vehicle Settings/Trunk Lid Restriction
Activate or Deactivate the function.
This function allows you to avoid bumping the trunk lid on a low garage ceiling,
The unlatch and latch function works but power up and power down do not. I believe I need to check the fuse and circuit for the up/down function but haven't had time to check it out today.
Thanks again!
I'll need to visit the dealership sometime anyways as I need a second key but having diagnostic capability at home would be nice as I'm sure there are many issues that pop up that could be fixed at home.
Thanks again!
I checked the connections to the open and close switches and everything is nice and tight so I believe I may have a bad trunk lid control module. I still need to order the Thinkdiag tool but wanted to ask if this tool will be able to diagnose this module and the inputs leading to it.
Thanks!
It's from Amazon so if it doesn't work you can send it back.
The trunk has a code of B224E55 - the trunk lid/tailgate control has a malfunction. The component is not configured.
on Measurements and Switching Thresholds, the normalization of tailgate shows not normalized.
Is there a teach in actuation in the thinkdiag?
I found a video with the code where the tech fixes what appears to be the same issue I have and he does it all with the Xentry(?) Software. Unfortunately the video is in Arabic and my Arabic is non-existent.
The opening of the trunk does not seem to be signaling the power actuator to raise to the fully open position.
This would happen when a module or motor is replaced or defective.
You can peform the normalization with xentry but if there is an issue (e.g worn hardware) the control unit will again fault and ask for normalization.
After reading, I have to assume that if the module itself is bad and I need to replace it that it's not just as simple as removing the old one and installing the new one. The new one will have to be programmed in order to work with the car and if that's the case, I'll have the stealership tell me what's wrong before buying parts.
One of these days I'll do the ILS upgrade through one of them.
