S-Class (W222) 2014-2020
M176 S560 Valve cover gasket leak
Old Apr 8, 2026 | 01:55 PM
  #151
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
"Hexolobular" btw is the ISO technical name for what most of us know as a TORX screw ... I had to look it up!
Old Apr 8, 2026 | 03:08 PM
  #152
jmattioni's Avatar
2014 SL65 AMG, 2018 S560
Originally Posted by Carl Wertz
Hi all,
About a month or so ago I posted about oil leaking into the boot where the coil packs are from the drivers side value cover.
Dealer cleaned it out, and replaced coil. They also added a leak detection agent and came back to do a oil change, service A was due. No "major" oil leak but there is some oil seen on the engine parts not like it was last time.
Soooooo, my ask to everyone here, should I do the work to stop the "leak".
Miles driven to see the small oil concern, 1500 miles and no major oil coming from the area suspected. I plan to do oil changes every 5000 miles now and check for the "leak" then.
Miles on motor, 88000.
Looking for any advice, and how many other people saw this issue on the 2019 motor?
Is it worth fixing or give it few cycles to see how bad it is first?
Thanks all for any input.
The fix is expensive so don't get it if you don't really need it. If it's dripping oil onto the undershield or, worse yet, you need to top off the oil between changes then, yes, I'd get it done. In general, I don't think the valve cover leaks are ever that bad.
I have the same problem on my 2018 S560. I cleaned it up when I replaced the coils and spark plugs and will monitor it from there.
Old Apr 8, 2026 | 03:56 PM
  #153
JohnLane's Avatar
222 S-65
Several cans of 'brakecleaner' applied can and will wash off all the ick. Remove plastic under the car before doing so. Multiple layers of cardboard under the car to catch the drips. Allow enough time for it to evaporate. Don't spray on a hot engine.
Old Apr 8, 2026 | 05:23 PM
  #154
My car does not require any oil between changes nor is there any sign of oil on the undercover or anywhere else, only down in the plug bores. It does have a slight burned oil smell unfortunately.
I would guess the valve covers leak just a few ounces total over a year's time.
Old Apr 8, 2026 | 05:28 PM
  #155
JohnLane's Avatar
222 S-65
If even that! Half a dozen drops of oil spreads out to collect a mountain of dirt.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
