S-Class (W222) 2014-2020
Strange Turn Signal Message
Old Jun 9, 2024 | 07:01 PM
ElastomerGuy's Avatar
2017 AMG S65 Cab 2024 S63 AMG e Performance
I’m getting a message on my dash that indicates that I should check the right rear turn signal. Funny thing is, it appears that all turn signal indicators on both the right and left side are fine. Anyone got any idea what might be going on?
Old Jun 10, 2024 | 07:35 AM
W205C43PFL's Avatar
Time to plug a scanner in and see if there are stored codes, it might have a more detailed message of what might be wrong.
Old Jun 10, 2024 | 08:04 AM
Katie22's Avatar
18 AMG GTC and 22 F150 Limited. Past owner 16 Maybach, 17 Brabus Smartcar, 06 Ford E150, and 22 G70
I think I myself would gently remove the panels in the trunk and do some connector removal and cleaning and reconnecting on any black boxes you find in there.
Old Jun 10, 2024 | 10:09 AM
W205C43PFL's Avatar
That gives me an idea, might be a battery issue. How old is the battery OP? MBs are very particular with the battery and their electronics are therefore sensitive.
Old Jun 10, 2024 | 11:10 AM
Katie22's Avatar
Oh one more thing. Under the seats are often the modules for many things for the car. The connectors to the black boxes are often a cause of problems because the SEATS move a lot forward and backwards ect.
ON my GTC for example the steering column stopped going up and down and sure enough a connector under the seat needed to be cleaned and reconnected.
Old Jun 10, 2024 | 01:13 PM
W205C43PFL's Avatar
That is true, been there done that glad you mentioned it! Hopefully that solves OP's problem!
Old Jun 10, 2024 | 09:26 PM
Mitch Alsup's Avatar
Top Answer: 1
S600
Something is going on in the CAN bus.
ECU send message to rear light to turn on or off but an improper message is received back from the tail light.
Old Jun 11, 2024 | 03:45 AM
Thanks for the suggestions, everyone. I’m going to do some investigating and connector cleaning this weekend. I presume the battery is original so 5 years old. I’ll check that out as well. Again, thanks to everyone who responded.
Old Jun 11, 2024 | 09:06 AM
W205C43PFL's Avatar
You're most welcome! Hopefully you figure it out please keep us posted.
Old Jun 16, 2024 | 06:04 PM
I asked the Benzninja if he might be able to help me with this issue. After he connected up with my car, in about 10 minutes, he had the issue resolved. He said the issue was that the MB sensors are sometimes too sensitive. So, he reset the error. Has not yet reoccurred so hopefully it's fixed for good. The Benzninja really knows his stuff.
