Leaking valve cover gasket helo
Hey all, so I have a good friend of mine who has a 2019 w222 s560, and has a small amount of oil entering his cyclinder 8 spark plug area. So the valve cover is leaking from what I gathered. Not much info out there, but I did find one post saying the engine needs to come out for a valve cover replacement?? I looked at his car, and it looks like it can be done with motor inside which of course all the other items removed away from the valve cover. Any suggestions? Car has only 56k on it
MBNUT1 (07-04-2024)
2010 E350 4Matic
This is interesting. @SW20S had his replaced recently at around the same mileage as I recall.
Received 2,696 Likes
2020 S560 4Matic
Yep, just had this done. Very interesting you’re having this done too. It’s a big job, it can be done with the engine in the car but they have to dismantle the whole front end and take the turbos off and the whole cooling system out to get access. 24 hours of book labor.
Is he under warranty? God I hope so.
No mentions of any of that stuff being done in the repair book. No front end removal, no engine out removal. M177 m176 motors in a w222 chassis based on the vin I provided to him.
2020 S560 4Matic
I'm just telling you what was done to mine, and Mercedes paid for mine so I guarantee they did it the most efficient way. My independent mechanic also said that was the best way. If you look at my thread the service order is posted there along with all the parts replaced and the procedure used.
Here is the link to the thread:
https://mbworld.org/forums/s-class-w...sket-leak.html
