Why does everything wear so fast?
The V12 s are bad but that's just because it's a dinosaour but if you got the V12 you knew it was stupid.
The rest of the range is pretty decent on maintenance.
These are big heavy cars, and yeah they go through tires quickly and brakes, but not every 10k. An AMG one maybe.
Mercedes has a very aggressive factory maintenance schedule…meaning they over maintain.
you want long lasting tires? buy a EV or hybrid - them tires designed for super low rolling resistance - fancy word for low dynamic friction coefficient aka low rolling grip.
There is no cheating physics. Ask this much weight to accelerate, decelerate and change direction the way it is able to.... Yes; it eats tires.
I don’t cry about it as I love how the car performs. I love how she shoves me in the seat. How she dances through the turns.
If I wanted tires to last forever I may drive a base model Corolla or some other yawn inducing junk that isn’t able to raise my heart rate.
OP I assume you drive the Corvette as it amuses you to do so. We get to maintain them.
There is sooooo much more to life than good gas mileage.... or tire life.
Shorter spark plug life is an issue of all turbo engines. Normally aspiration engines can go 100k on a set of plugs - turbos require change at around 50k. Not just a Benz thing.
if you drive like grandma tires last longer than if you drive like a race car driver.
As to brakes:: do not use Distronic-Plus where it make constant speed corrections:: each correction
uses more of the pads.
If you see that you have to come to a stop, take the car out of gear and coast to the stop.
As to brake fluid:: when tracking a car you want fluid that is less than 1 week old.
when driving normally you can go quite a while--
just don't attempt multiple stops from 150-MPH in a row.
As to trans fluid:: compare the cost of the fluid to a new transmission and make your own choice.
Also note: using high engine HP heats up transmission components shortening the
life of the fluids.
As to spark plugs:: if you let the plugs get to the point they misfire; you can take a coil pack with the plug.
Simple to resolve - it all comes down to the basic fact OEM - FRONT & REAR “CAMBER ADJUSTMENT” HAS BEEN DELETED.
NO LONGER THE ABILITY TO ADJUST TIRE CONTACT ANGLES SPREAD LOAD MORE EVENLY. Excess edge load can also lead to ruptured side walls and rim damage.
NEW CAR INDUSTRY'S BEST KEPT SECRET - The Often Quoted Re assuring “WILL CARRY OUT “FULL FRONT & REAR ‘4’ WHEEL ALIGNMENT” - IS NOW ONLY “TOE” - directional adjustment (Even W222 AMG S63/65 Performance models).
WHY - IT’S ALL TO DO WITH COST CUTTING AND “EVER INCREASING SPEED” OF NEW CAR ASSEMBLY LINES. Camber (and Caster) is now at one setting only - showroom height (STOPPING TO ALIGN / ADJUST IS NO LONGER AN OPTION).
NOW NO “ONGOING ADJUSTMENT” - to cater for excess passenger side edge wear through high cambered roads. Wheel squat / camber change causing excess “inner” edge wear on both sides through extra passenger loads or lowering vehicle height. Fitting wide profile tires or performance / spirited driving and not being able to adjust, compensate for excess “outer” edge wear !
ALL DEALERS CAN OFFER OBSERVING THE EXCESS EDGE WEAR (to try and placate) - that it is within factory specs (at showroom height).
K-MAC HAS THE EXPERIENCE OF RESOLVING OEM SUSPENSION SHORTCOMINGS SINCE 1964 !
WE SAW THE NEED THEREFORE TO PROVIDE FRONT CAMBER (AND CASTER) ALONG WITH REAR CAMBER (AND EXTRA TOE).
K-MAC KITS SPECIALLY DESIGNED SO “BOLT-ON” - No special tools or need for control arm removal to install.
SEE SPOILER (TO FIX IT RIGHT - THE 1ST. TIME).
AUDI to VOLVO - K-MAC Experience Of Resolving OEM Suspension Shortcomings (and Costs) Since 1964 !
