Low beams really low
I’m wondering if some setting isn’t correct?
In all seriousness, yup they can be adjusted you pop the hood and you use an allen key to adjust the headlight if I recalled correctly.
Ps, “Fog switch?” Where is that? I feel like I’m driving the Batmobile. Where’s the anti-pursuit switch that throws out an oil slick, or the nails?
Wouldn’t it be wise to use a headlight alignment tool instead of in front of a wall. In PA we have state safety inspections and the mechanics will run their “Gottcha!” App to find anything they can charge for (and sometimes even make up crap that’s wrong only to them!). Ten years ago it took a half hour to do one of these inspections, since then shops have discovered just how profitable these “Safety” inspections can be, now taking over an hour.
I took my Silverado to a Mieneke shop 2 yrs ago. They hit me up for a torque setting adjustment - the front hub nut was off by 35ft lbs. The fee, $65 for 0.5 hrs shop rate.
Thanks!
Alignment is performed with a complex set of tools now as there as some interactions between systems such as the night vision spotlight; but yes you can still turn the screw to move the lights.
One of the drawbacks of high intensity headlights, be they LED or HID is that they have a sharp cutoff to avoid blinding other drivers. If you’re not used to that it can be annoying at first. The ILS solves that issue
I’d contact and get with @EleBest , sponsor forum vendor here, for ILS IHC coding and I think that should address your concern.
Keep in mind that ILS is not like magic and there will still be times when high beam won’t stay on, but at least it will be available under most conditions.
I posted about my personal experience with ILS coding here if u want to learn more https://mbworld.org/forums/s-class-w...-low-cost.html
Take a look at our website, you'll save up to 90% on all your future repairs compared to the dealer
I pushed the turn signal stalk forward and the light control dial is straight up on “Auto” - It’s just low beams. With the turn indicator stalk in the middle nothing but if I turn the light dial to the right the high beam is on. The high beam is again on when I pull the stalk towards me.
I drove this car last Monday night - low and high beams were just fine. The only thing I can think of is to drive to the Mercedes showroom near me and ask someone there about this. After I run the clock out for the 10 day guarantee this Thursday and I pass the point of no return, then I’ll be looking for the ILS+ to be added.
OP get with BenzNinja, get the computer and membership. Peter offers many software tweaks that do good things for your car. Just do it.
Highbeams
A minute later with low beams
Lowbeams
High
The lowbeams
Another minute later
