2020 450 vs 560 - which engine more reliable
low mileage 20,000-30,000 miles
I usually drive my cars to 120-150k miles
which engine is more reliable 560 or 450 on 2020 S class ?
thanks
That said, the S 560 will be smoother experience over all due to more cylinders.
The M256, as an inline-6 cylinder engine, should be more reliable, but without the 48V system, there is turbo lag and hence the ride feels sluggish and not as smooth (you’ll find a need to push the accelerator harder which causes harsh shifts by default). I chose the M265 in the GLS (and would do the same probably in a W223) only because the engine uses the 48V electrical system to operate an electric supercharges which spins up to 10s of thousands of rpm to reduce turbo (almost no lag at all); very smooth and very reliable .. and in that case the ride is VERY subtle combined with the reliability benefits. 48V and the electric motor isn’t an option in the W222, so make sure to drive one first and see if you’ll like it.
The biggest potential issue for the M176 seems to be leaking valve cover gaskets which my unit had and a couple other people here have had. That can be a big job, and it can pop up before 50k miles. Most people realize theirs leak when they do their spark plugs at 50k miles. Something to just be prepared for and try and get addressed under warranty like I did. I would not own one of these without a warranty.
But I would never even consider the S450, personally.
My advice would be to look for the car with the best service history. I would have gladly bought an S450 if it had the options I wanted plus a great service history.
I’d love to know the back story on the single prior owner. He cleared loves this car too.
Attached is the datacard. No pics yet as I’ve been sick and it’s been raining.
