M279 motor
Thanks! OP The 279 is excellent. Individual coils for each cylinder means that problem in the 275 is solved. Engine mounts are a different design than what was used for the 275. I have not needed to replace them yet in my car that has 140,000 miles. I got to replace a water pump in mine at 125,000 (roughly) miles. Otherwise smooth sailing.
Tack Jl för att du delar med dig om dina erfarenheter av din bil😊
tänker ta en bil från Tyskland i vår och tänker mig göra all service själv.
Har du själv gjort någon flush av ABC/MBC suspension på din bil?
Kent från Sverige.
Kent från Sverige.
2019 W222 S560 4Matic/2025 Yukon Denali
If you are on a chrome browser or chromium based browser right click any empty space and hit translate to English, anyways translated seems to be
" Thank you Jl for sharing your experiences with your car 😊
intend to take a car from Germany this spring and intend to do all the service myself.
Have you done any flush of ABC / MBC suspension on your car yourself?
Kent from Sweden."
Kent from Sweden."
Ancient IPad that is unable to run on newer software. Thus; no translation. Thank you for the Google tip.
Kent... MBC fluid gets flushed every 30,000 miles in my cars. Very easy to do. Filter is said to be built into the fluid reservoir. I have not replaced it, but keep fresh fluid in the system. Only failure with MBC has been the pulsation dampener that threads into the MBC pump. Very easy replacement.
