12V battery partially charged
I'll turn on standby mode before I leave.
To know if standby mode is activated, lock the door and see if the red anti theft alarm light is flashing (forgot where it is on a W222 but close to the clock I think), if the doors are locked and the light isn't flashing anti theft is disabled and is disabled by standby mode.
As mentioned above double click the lock button when you leave the car, I know it shuts the key down, not sure if it disables the vehicle's keyless/security functions.
Finally, while working on the car with the doors open and the ignition on, I got a warning about low battery, and there was a hidden code about battery resistance being high.
I finally swapped out the battery (5 years old at the time), and the app now shows fully charged, no battery resistance hidden code, and no more worries.
Stand-By mode is not available if your battery is not fully charged.
Driving your car 30 minutes will not fully charge a low battery.
Buy a CTEK charger and use it religiously.
AGM (Absorbant Gas Mat) is also a lead acid battery.
Outside of the very few new exotic batteries available, all of the batteries you will find for automotive use is either lead-acid or lithium.
You will need a different charger if you want to go Lithium but all other Lead-Acid types will charge as expected with this type of CTEK.
