S-Class (W222) 2014-2020
turbo coolant lines parts
Old Mar 9, 2025 | 09:27 PM
vdubpower's Avatar
i drive them all, fast and hard
2015 s550 160K
the front line snapped. Unfortunately they were all original.
This is a spare car, we just need it to run. It has a lot of top end chatter and also turbo actuator valve that is bad causing cel. We dont care to sort those things because basically that means a new engine
We just need to get some new lines, maybe a WP and whatever is needed pertaining to cooling to get us back going
Does anyone have a list of parts I can start to order, and also are these parts the same as w1212 e63 m157?
thanks
Old Mar 23, 2025 | 05:30 PM
kennis39's Avatar
2012 Mercedes benz s550 4 matic
turbo coolant hoses for a s222
Hello Did you find the part numbers to the coolant hoses you need. I have some broken hoses beside my water pump that I need replaced as well. My car is a 2012 Mercedes benz s550 4 matic biturbo.
Old Apr 7, 2025 | 09:49 PM
Turboaction's Avatar
2015 S600, 2014 E550 4-Matic
Don't give up on the low boost/turbo actuator valve. My wife's E550 had a code for low boost, and all it needed was a $10 check valve for the vacuum pump on the rear of the engine, and the wastegate actuator hooked back up with a new E clip. Don't give up on the ol' girl!
Old Apr 8, 2025 | 02:40 AM
vdubpower's Avatar
2782001300
2782000900
2782001400
2782000800
2782001851
But i need the experts to confirm this. I am not sure
and i dont know what other bits i need, water pump, thermostat, other bolts, and screws, covers etc
please assist
also how did u change the pin in the actuator with out removing the motor
