S-Class (W222) 2014-2020
W222 Standard Burmester wiring diagram
Old Apr 15, 2025 | 01:08 PM
seele2's Avatar
Mercedes Benz S560 Renntek tune
Hello All, i'm going to be attempting my audio upgrade this weekend. i'm going to add a sub in the trunk. does anyone know where a wiring diagram for the speakers on the standard burmester is located (PDF). I've seen people say its the blue wires. I'd like to use both the left floor panel and right one to go into the Helix Hi/Low converter. thanks.
Old Apr 15, 2025 | 01:13 PM
seele2's Avatar
after looking i found the below screen shot. Another posters said its for pre-facelift w222 is that correct?
Old Apr 15, 2025 | 01:56 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
https://mbworld.org/forums/s-class-w...ml#post7270402
Old Apr 15, 2025 | 02:18 PM
seele2's Avatar
i did try both of those and they are both broke... appreciate the help
Old Apr 15, 2025 | 10:13 PM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
The Blue/Blue White pair and the Brown/Brown White pair are the left and right front sub channels on the standard Burmester Amp located in the rear driver side trunk well just behind the rear wheel well. I did this upgrade several years ago and it was a huge improvement. I tapped those two pairs and sent that signal into an Audio Control LCi. From there I went to a JL Audio VXi1000/1 sub amp and JL WA7 10" sub in a sealed box. It was loud, very loud, too loud. Vibrated the car. Later on I did the rest of the channels with a JL VXi 800/8 amp and it was superb but then I sold the car and all the gear as I could not get it to work with my new S63 with the HE Burmester setup. To many nannies in HE system to overcome.
Old Apr 16, 2025 | 08:25 AM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
This link from @UrBusted works for me, are you not able to see it?
Originally Posted by UrBusted
If anyone needs it, here is a diagram for the entire car, sorry about how it's scanned, it was difficult to get this back when I was looking for it.
https://www.dropbox.com/s/3mfv5hw4nk...70828.pdf?dl=0
Old May 13, 2025 | 11:01 AM
joeyb1000's Avatar
2019 S450, 2020GLC300
sorry for not replying to this earlier. The document above is pre- facelift. The one I am attaching is post facelift. These are the wires running from the amp to the woofers under the dash. Using the “dirty” signals is advantageous because many amps will use this to turn on/off.
