Chronicles of a 2015 S600
I've owned this beautiful, rebuilt title 2015 S600 for about a month. When I went to test drive this car, it had a coolant hose dragging on the ground, and was missing the lower engine covers. The car is well optioned, only missing the 3D sound system and the rear cooler. This was the lowest priced W222 S600 at the time, by about $20,000 USD, so I decided to make the purchase anyway. But the car wasn't really drivable.
I pulled the part number from the diverter valve that had been broken, A0005003040. Of course, that part was not available from MB, and neither were any of the parts it had been superseded by. I got frustrated, and purchased an "OEM" diverter valve for about $90 on eBay. I installed the diverter valve, topped up the coolant in the expansion reservoir (good job M277 engineers for adding this). I drove the car about 20 miles to work, and on my return home, noticed the car was dripping coolant. This time it was from the low temperature cooling circuit drain plug. The plug had been cracked when the previous owner/thief/whoever had broken the diverter valve. On this drive, I also learned none of the multi-contour pneumatic seat functions were working. Oh, and the car started running rough and threw a misfire code for cylinder 8. On my first drive! I thought the M277 had a better ignition system than my comparatively ancient M275.
I ordered a new drain plug, and associated hose, since it also could have hidden damage. I also ordered a C4 multiplexer, since my C3 won't communicate with the car, so I can't figure out what's going on with the seats. 24 spark plugs and an ignition coil were also in the mail.
Fast forward 2 weeks, and I've installed a few new underbody panels, transmission cooler hose assembly with drain plug, spark plugs, and #8 ignition coil. I installed a 2017 version of Xentry, and got the new C4 multiplexer working after learning I needed to assign an IP address to my virtual machine to establish communication. I check the faults, and the seat pump has been deactivated because of a leak. I clear the fault, check the pump and purge valve. Both are working normally. I check the powertrain control module, and it has a fault for the coolant circulation pump. I turn the pump on via the actuation menu, and it runs! But the fault persists.
The next day, I decided the low temperature circuit must be full of air from the previous accident/hose replacement. I pull a slight vacuum on the system with my transmission oil drain/fill system, and push nearly 2 quarts of fluid into the system. I bleed the intercoolers, and the pump is now clearly circulating fluid. Now there's no longer a coolant pump fault either. Victorious, I then think to myself about how the transmission cooler likely had no coolant flow, and I probably toasted my transmission fluid on my commute to work. But that's a problem for future me.
Two Suspensia lower front control arm links are sitting in a box. These will go on soon to try to resolve my high speed vibration. Or it could be the Mucho Macho tires. And of course my 18" Monoblock AMG wheels don't fit. Why would they?
I had a 2007 one owner S600 that I purchased with less than 24k miles in 2014. It was a perfect car that was serviced meticulously from day one. Thankfully I was able to purchase an outstanding warranty on it. In just 3 years and 23k miles, that warranty paid out around $24k in claims before I threw up my hands and said "no more" as it was in all the time for service work. I loved that car and all of the features it had, the way it drove and handled, and the imposing body of the W221. But reliability was definitely not its forte as even a never-abused low mileage Benz V12 can be a bank breaker.
When I purchased my current S550 almost 5 years ago, I had actually considered a 40k mile 2015 S600 because from reading this forum I was told that many of the issues with the Benz V12, although 98% the same as the one I had were sorted out. But I found out that NOBODY offered a warranty on a Benz V12 any more, so I stayed far away from it. And I'm extremely thankful that I did.
Good luck in your adventures with your car. But don't be afraid to throw in the towel at any time.
Here's the thread. Hours of entertaining reading.
The 222 car doesn’t need so many of the annual repairs the 221 car got.
Enjoy.... once she’s up to speed.
Oh.... as mentioned above... get some good forged wheels to replace the junk on it.
I ordered 1 month before COVID hit,
they quoted 11 weeks
It took closer to 22 weeks with all the supply train disruption.
On Thursday the dealer sent a "transporter" to haul my car back to their location for a state inspection, because the title was rebuilt in Indiana and Illinois won't issue a clean title without it getting inspected in-state. I kindly asked that the transporter on the return trip utilize a trailer with fenders, and legal equipment. As far as I can tell, this car was never wrecked. All of the bumpers and other parts still have the original manufacture date. It's amazing that it has a branded title from a theft recovery, but such is life. The way I own cars, I'll probably have this one until it's fully depreciated, and it'll be worth more in parts regardless of the title status anyway.
My honest but hmble prediction is this will be an unmitigated disaster! When it was first posted I thought this was a terrible idea. But after this last post I'm even more convinced this will turn out terribly, and I didn't think that was possible. This seems like a joke. The "dealer" sent a transporter...you call that a transporter??? That's not a flatbed, it's a ford Expedition with a old rusty trailer with bald tires. Are you kidding me? And I'm even more astonished that the car was bought from a dealer. No wonder it was only $20K less other cars available, it should have been $50K less, which is what the dealer paid for it. All this and not to mention they put "cosmo" tires and cheap replica wheels on the car. Google the VIN and see if it showed up on coparts or vinlocator. I want to see how this turns out because EVERY indicator says this isn't going to end well. Or maybe I'm missing something....
Carlos I hope that you are wrong in your assessment. Time will tell.
The whole used Mercedes market is an interesting one. Within 100 miles of where I live, there are 2 or 3 dealers that are buying every E63/CLS63/S63 Mercedes they can find in the $20-$60K range. They detail the car, reset the check engine light, put the cheapest tires/wheels imaginable on the car and list it for sale. One of the dealers is buying all the wrecked ones and piecing the cars together. They sell almost exclusively to online buyers, many who likely never realize the history of the car. The dealer my car came from was in the Southeast side of Chicago, so you can imagine the market they cater to.
The way I look at it, the dealers can renew their license, scour online auctions, make acquisitions, detail the cars, and then list the cars and sit on inventory in order to make a few thousand dollars. Multiply that by enough cars, and I guess you can pay a few salaries in the used car business.
Now, if I can only get Autohaus Parts Delivered to cancel or actually submit my order for some screws, clips, and an underbody panel. They have been sitting on my order since April 4th and won't answer calls or emails. They're local, but I'm not sure they're doing OK. The parent dealership is in a lawsuit for shady business practices, so that may be affecting their operations.
I don't think I've ever claimed that Mercedes ownership was drama free. But it's worth every second. What reasonably reliable car could possibly be more enjoyable to drive in cold weather than a W222 S600?
OP, I'd love to research your VIN, care to post it or send me a PM?
Sold 2015 Mercedes-Benz S 600 Sedan in Crestwood
Honestly, I think I can sort the car out as long as a title is issued. The main reasons I wanted to upgrade from my W220 were to have functional cruise control, native bluetooth audio, and better parts availability. My expectations were pretty low. Sadly, the liability insurance on this car is almost double what is was for the W220, so this will be some expensive cruise control!
Is the electric power steering experience better than the W220 hydraulic steering? No. Do I need huge front brakes that require 19" wheels? Nope. Will this car provide comfortable transportation in the cold weather months? You bet it will!
The heater doesn’t cook like my Volvo 240 did decades ago but is sufficient.
Never a foggy window in the 221 car. I’ve never had the 222 car in cold + wet to try out the defroster but A/C takes water out of the air.
I hope she proves to be all that and then some. I sure love my 279 powered car.
Next on the list is to clean the instrument panel screens, and possibly apply a screen protector (one of my panels has some smudges and I'm already preparing for the worst). I may also order a functional window shade while I'm at it. Most importantly, I plan on driving the big girl, and applying a wax/ceramic coating (Project Farm approved). Before winter, I'll spray sheep extract in the doors and in the rear wheel arches to help protect the critical areas from corrosion.
And yes, I know I need to install the drywall above my garage door. The bricks on the front of the house were sagging, so I had to support them, reinforce the beam across the garage span, and then get the garage door and spring back together before the wife got upset. Then, priorities...
One question for fellow V12 owners: Does the car seem to be torque managed in the first 2 gears? The car seems to be running fine, but it doesn't flash the orange triangle quite as much in the lower gears vs my W220. Maybe the traction control just manages the toque a bit better for the available traction. I haven't looked to see if there's a way to turn off traction control yet. In the past when I took the W220 to an auto-x event, the car performed the best with ESP disabled. Dyno mode was notably worse, as it disabled the ever-so-awesome torque vectoring in the corners.
Today I nearly eliminated all of the vibration that peaked at 65 mph by applying aluminum tape to the inside pilot of the Chinese wheels to help them hub-center. I should be able to keep these knock-off wheels around as a winter set after all! Next on the list is to change the transmission fluid and filter. Since the low temp circuit was open, there's a good chance the transmission fluid may have reduced life. The fluid is 10 years old and has almost 95K miles on it, so it should be changed anyway!
I drove some coworkers to lunch this week. One is a fellow W222 owner, and another was in the market for a Chevy Blazer. After riding in the back, and front of the S600, he's now considering a BMW X5, but really wants something with Mercedes level massaging seats. It's a slippery slope...
