S-Class (W222) 2014-2020
Thermostat Price Insanity?
Old Apr 29, 2025 | 02:56 AM
BBBAAUTO's Avatar
There is nothing "performance" oriented about plastic parts on the engine. At best you save a few grams on weight, have a mal-adjusted heat cycling part that will fail sooner, all because there was a meeting between finance supervisor and engineering team that realized they could save $19 dollars across xx,000 units equaling y amount of savings and sell w more engines, gaskets and housings because of said decision. NOTHING about plastic is performance oriented and in fact shortening the life expectancy is the complete opposite...; heat cycles.... leaks... you get the picture.
Old Apr 29, 2025 | 12:59 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
2 things can be true at the same time. What @SW20S is saying is that when it comes to a car like this, you have to pay to play, and everything will be more expensive, and I agree. And your point about cost being a concern when developing new mechanical parts is also right. Your point don;t cancel each other out. However, this engine was designed by AMG for MB, even though AMG is now inside MB. Packaging was also an issue; they had to account for the different applications too. So when you balance, cost, preformance, application, they arrived at the lowest common denominator. End result; it sucks to have to replace one of these things!
My hope for the OP is that he will get his OVS replaced at the same time since they will already be that deep into the engine, the thermostat housing is in between the OVSs onthe front of the engine. The parts are "relatively cheap", and if it only cost a couple hundred dollars more it would be more than worth it.
Old Apr 29, 2025 | 01:15 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
Plastic saves weight, and the lifespan difference is not necessarily as distinct as you think, modern plastics are very resilient and long lasting.
Old Apr 29, 2025 | 01:30 PM
MBNUT1's Avatar
2010 E350 4Matic
Originally Posted by SW20S
What you have to understand is this car (and every other car like it) is designed for performance first, and repair and maintenance cost second. It's not designed for you to buy it when its 5 years old and drive it until its 15 years old and not have to pay for any repairs. That's a Lexus ES. You can't even expect that with a Lexus LS (I know, I've had 4). If you are concerned about maintenance cost, no car like this is for you that's just the bottom line. Just get a warranty, or just be happy with a much less complex and more reliability focused car.
IMHO this represents an evolution in product philosophy from one that rewarded higher price point with a long term hold to one that is best suited for the lease market.
Old Apr 29, 2025 | 01:33 PM
SW20S's Avatar
2024 S580
Originally Posted by MBNUT1
IMHO this represents an evolution in the product philosophy from one that rewarded higher price point with a long term hold to one that is best suited for the lease market.
This car has been a lease machine for 30 years, and thats the model that makes sense for the manufacturer.
Old Apr 29, 2025 | 05:08 PM
Highline-Autos.com's Avatar
SPONSOR
2001 E55AMG
Originally Posted by S-Klasse MB
I have a 2020 S560 sedan. I'm getting a check engine light, which when read, is code P0128. I'm guessing this likely means the thermostat is going bad? Is there a way to tell if it's just the sensor instead? I went to look for where to order a new thermostat and pricing, and it seems like the thermostats are only sold as the whole housing? Is that right? Wondering if there's an aftermarket option for just the thermostat, but haven't found one yet. I was floored to see a $745 price tag for a damn thermostat housing, with no option seemingly to order just the thermostat by itself. Anyone have any experience with this and recommendations?
I'm showing $712.00 for the Thermostat Housing and 6.3 labor hours to remove and replace.
Trenton O. Gibson
tgibson@highline-autos.com
Highline Autos
Direct: 602.909.9216
Office: 480.348.0777
Old Apr 30, 2025 | 02:15 AM
  #32
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
they fail at the gasket before they fail at the plastic housing, the transmission pan being plastic sucks though but those things rusted/became porous over time all the time anyway
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Apr 30, 2025 | 06:52 AM
  #33
MBNUT1's Avatar
2010 E350 4Matic
Was hoping that the W222 had fallen in the footsteps of the W212 and returned to old school robustness. IMHO the V8's don't meet that standard.
Old Apr 30, 2025 | 12:11 PM
  #34
SW20S's Avatar
2024 S580
It’s a very robust car with surprisingly few major faults, but like any such complex car it’s not going to be perfect and there will be big bills as they age. It just is what it is.
I would have kept my S560 and driven it to 100k miles without hesitation, but I would have kept it under warranty.
Would I keep my S580 to 100k miles? Probably not.
Old Apr 30, 2025 | 12:20 PM
  #35
W205C43PFL's Avatar
You also had a valve cover gasket leak so that was discouraging.
Old Apr 30, 2025 | 12:32 PM
  #36
SW20S's Avatar
2024 S580
Sure, but it was covered under warranty and I would do 5k OCIs to avoid it happening again.
Old Apr 30, 2025 | 02:03 PM
  #37
W205C43PFL's Avatar
Was it confirmed it was caused by long intervals?
Old Apr 30, 2025 | 04:04 PM
  #38
SW20S's Avatar
2024 S580
Thats what both the lead tech at my dealership and my independent Mercedes specialist said. Its caused by clogged oil separators and shorter OCIs keep them from clogging. In the S580 I am doing 5K OCIs.
Old Apr 30, 2025 | 04:20 PM
  #39
W205C43PFL's Avatar
I see. Interesting observations and thank you for sharing, sticking with lower OCI it is then.
Old Apr 30, 2025 | 04:24 PM
  #40
MBNUT1's Avatar
2010 E350 4Matic
Any car that would compel one to own under warranty between 50K and 100K doesn't meet my standard for engineering excellence.
Old Apr 30, 2025 | 04:32 PM
  #41
SW20S's Avatar
2024 S580
Then this caliber of car is simply not for you. I wouldn't have owned my Lexus LS sedans without an extended warranty either and they are firmly regarded as the most reliable cars in the segment.
These cars are incredibly complex and expensive to repair with expensive parts. Its not a Camry or even an E Class. You have the potential for engine repairs obviously but then you have all the technology, air suspension etc. If you want to drive one of these without a warranty you have to be prepared for the potential of a $5k repair at any time.
Old Apr 30, 2025 | 10:07 PM
  #42
S-Prihadi's Avatar
M177 engine for thermostat is the King of Nightmare labor wise.
M278 or M157 will seems like a walk in the park for the same job.
M177 being a hot Vee is hot on the wallet too, for thermostat replacement and too bad Master Tasos seems to do a lot of it...meaning it is not that reliable , the thermostat.
Non MB specialized techy, but a very senior and capable techy.
Naked engine walk around. Good to visualize the challenge of doing X-Y-Z job on it.
Happy maintenance boys.......
Old May 1, 2025 | 02:30 AM
  #43
Kent agent's Avatar
S600 w222
S600 w222
HEJ
Det är allt som detta jag köpte en s600 istället för problemen med V8 w222
Old May 1, 2025 | 02:32 PM
  #44
MBNUT1's Avatar
2010 E350 4Matic
Would be happy with the ride / maintenance trade ("pay to play") on the air suspension. It is pretty well sorted on the W222 and worthy of the benefit risk trade. Not seeing that with the V8 engines.
Old May 1, 2025 | 03:18 PM
  #45
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
This thread seems to have taken a detour so I want to clarify.
The electric assisted thermostat is not new, it has been in use by MB for over 20 years. Failures are very rare as lifetime far exceeds traditional thermostat.
There is a manufacturing defect on a specific batch of M177/176 thermostats that makes them very likely to fail open due to a component coming loose (some countries will have extended warranty for this).
Old May 1, 2025 | 04:05 PM
  #46
Top Answer: 1
Trenton O. Gibson
Highline Autos
Trenton, didn't you say on another thread that there is an extended warranty for thermostat replacement? I thought you said that Fletcher Jones is aware and takes car of this under an extended warranty from Mercedes-Benz. Or was I mistaken?
Old May 1, 2025 | 04:31 PM
  #47
SW20S's Avatar
2024 S580
I would not buy a S450 without a warranty either.
Old May 1, 2025 | 08:41 PM
  #48
MBNUT1's Avatar
2010 E350 4Matic
The M276 is a well sorted proven engine.
Old May 1, 2025 | 08:49 PM
  #49
SW20S's Avatar
2024 S580
But the car is still incredibly complex with tons of things that can go wrong. The engine is only one component.
Old May 1, 2025 | 09:18 PM
  #50
MBNUT1's Avatar
2010 E350 4Matic
What components are unique to the W222?
