I have identified the dreaded oil seepage in the cam magnets on my S550, and plan to replace them.
Drivers side upper magnet is blocked by a few plastic lines feeding into the oil filter and wondering if anyone can suggest a practical plan to remove them.
Note that I will also install the pigtail segments on the electric connectors after replacing the cam magnet sensors...belt and suspender approach.
waterzap99
close
- Join DateJul 2023
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I driveS550 V8, CL600 V12, SLK32 AMG
Liked:91 Times in 70 Posts
I had the same issue. In the end I took the front covers and everything else off too. I did post some pics. If you look at those lines wrong they will break.
Baltistyle
close
- Join DateFeb 2017
- LocationBaltimore County, MD
- Vehicle(s) I drive'13 s212 63 p30. '06 LX470
Liked:1,204 Times in 853 Posts
There’s a thread that is pretty involved for both the M157 and M278 engines. Try to find the video on YouTube of the 278 engine because it is significantly (many hours and parts)less work for that engine. That video was posted here as well, but I’m not so great at the search.
MAKE SURE that you replace the bolts for those magnets because they are made of butter and your repair will become exponentially more difficult if you break one of them. Use a torque wrench and make sure there is no sealant in those holes at all.
this video is decent. https://youtu.be/01LS2ftmom8?si=GJS-WGwvb1xUZlvX
waterzap99
close
- Join DateJul 2023
Here was my story. Ended with everything in front taken off
https://mbworld.org/forums/s-class-w...placement.html
On the bright side, I have not had any leaks since I did the job. Not a drop of oil or coolant.
