Re-use lug bolts for 20" AMG rims for 19" AMG rims?
Subscribe
Jun 6, 2025 | 07:06 AM
I'm thinking about changing from 20" AMG OEM rims to 19" AMG OEM rims for better ride quality. Can I re-use my existing lug bolts?
Reply 0
Jun 6, 2025 | 11:05 AM
Yes, just measure to verify the same number of threads go into the hub for full engagement. Put a bolt into a hole on the 20" wheel and see how much of the threaded shank comes out in back, and then do the same thing with the new wheel.
Reply 2
Jun 7, 2025 | 05:03 AM
The EPC shows only one size lug bolt for the W222, M14 x 1.5 x 48.5mm. When I went from 19s to 18s (OEM) on my car I used the same bolts. mM14X1,5X48,5
Reply 0
Jun 7, 2025 | 03:41 PM
That was the case for my car when I went from one AMG wheel to another ... they use the same bolt length, but the sure thing is to measure them with each wheel
Reply 0
Jun 7, 2025 | 04:34 PM
There are two types of lug bolts, a ball seat type and conical type
Since you are staying with an OEM AMG wheels, the same bolts be fine other wise after market wheels use a different wheel bolts usually conical
You would be just fine if moving from AMG wheel to AMG wheel
Reply 0
Subscribe
Currently Active Users (1)
