S-Class (W222) 2014-2020
Oil change
Old Jul 16, 2025 | 09:11 AM
Kent agent's Avatar
S600 w222
Oil change
On Saturday I was thinking of changing the oil in the gearbox of my S600 w222 Wondering what type and dimension it is on the crankshaft nut to turn the drain plug in the correct position on the converter? Which way do you turn?Kent
Old Jul 16, 2025 | 09:30 AM
Digital Oxygen's Avatar
One of them there S cars
If there is a drain plug on the torque converter, should be a 5mm Allen (Internal hex). 27MM socket for the torque converter access plate on the bell housing. Clockwise rotation.
As I understand it, some W222 torque converters have the drain plug, some not.
Curious why you're not doing an engine running flush? I think this guy's way of doing it is best for removing all of the old fluid and getting a proper flush.
Old Jul 16, 2025 | 10:58 AM
Kent agent's Avatar
S600 w222
Thank you so much digital oxygen🙂Bought a comprehensive oil change kit, 12 liters of oil, so I thought it was enough as the car had only done 7000 miles
Old Jul 16, 2025 | 11:00 AM
At 7000 miles, I think you'd be just fine with a pan and torque converter drain.
