S-Class (W222) 2014-2020
S 550e OBD code P13D900
Old Aug 6, 2025 | 12:07 PM
hdediu's Avatar
VW Beetle Saab 99 Saab 900CD 500SEC 190E Previa Cayman S Mini Peugeot 508SWGT BMW i3 Panamera S550e
I got a check engine light on my 2015 550e which shows no other symptoms. Using an OBD reader I see only one code: P13D900 or P13D9. Searching everywhere online finds one hit, in Singapore, which after translating claims it's "Charging cable malfunction P13D900 = Plug cover lock has an open circuit." How do I confirm this? All the other hits are for glow plugs on VW diesels or, maybe camshaft position sensor fault on a BMW.
Old Aug 7, 2025 | 05:34 AM
Katie22's Avatar
18 AMG GTC and 22 F150 Limited. Past owner 16 Maybach, 17 Brabus Smartcar, 06 Ford E150, and 22 G70
What about considering clearing the code and seeing if it comes back. Perhaps it was a fluke.
Old Nov 20, 2025 | 09:07 AM
hdediu's Avatar
It comes back after clearing. I took it to a service center and they said only that it will cost 1200 eur to replace the entire charging system. It seems ridiculous.
Old Nov 21, 2025 | 06:30 PM
Alexie's Avatar
That code is for the charge port lock. It's a common issue on the plug-in hybrid.
Try locking the car with the cable plugged in. If you don't hear the lock click, that's the problem. The car will still drive, but it may not charge.
Old Nov 22, 2025 | 08:14 PM
hdediu's Avatar
Thanks for that. The car charges fully and there are no symptoms of any other problems. The error will not clear with an ODB II reader. I will try to see if it's a mechanical problem.
