S-Class (W222) 2014-2020
Start/Stop ECO Deactivation
Old Dec 15, 2025 | 10:21 AM
Barry Hanna's Avatar
'15 E350, '20 S560
Thumbs up Start/Stop ECO Deactivation
I didn’t realize it until yesterday, but the system is designed to deactivate when the ambient temperature is low, somewhere around 40° and lower. Fortunately, I live in Atlanta where this feature isn’t tested too often, but it was yesterday and probably will be again for the remainder of this week. There are other times when the “little green gremlin” doesn’t appear but I thought this case was interesting. Another detailed explanation brought to me courtesy of Grok.
Old Dec 15, 2025 | 03:05 PM
JohnLane's Avatar
222 S-65
Barry have Peter program your car to remember 'Last setting' and it will remember that you had it turned off... Thus; no annoying start-stop.
Old Dec 15, 2025 | 06:42 PM
Mitch Alsup's Avatar
Top Answer: 1
S600
Now, all we need to do is find the sensor and constrain it never to read above 40º !!
Old Dec 15, 2025 | 08:15 PM
Alexie's Avatar
Yep, that's normal. The system won't engage if the battery is low, the cabin hasn't reached your set temperature, or if it's too cold outside. It's protecting the battery and ensuring the engine stays warm enough. When all its conditions are met, the green light will pop up. It's a picky system, but it's just trying to protect itself.
Old Dec 16, 2025 | 06:25 AM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
100% agree on this, it should have been set this way at the factory (opinion) but at the time there was money in it for Mercedes if they could say they were saving fuel. Long term stop/start is not ever going to be good for your engine. @BenzNinja has the solution for you.
Old Dec 16, 2025 | 09:04 AM
streborx's Avatar
Top Answer: 1
G550
The cold temperature disable of ECO S/S is mainly a consequence of battery capacity which can be reduced to half at 32F/0C, and the less efficient charging at this temperature. Shutting off the engine and not having enough charge to restart it is avoided by disabling ECO S/S. It's easy enough to code off with OBD scanners, such as the Launch, which is what I and many others have done.
Old Dec 16, 2025 | 09:59 AM
GTIBlack's Avatar
Mercedes SL R231
It’s not a single sensor that controls the ECO START/STOP. There are multiple inputs, as stated elsewhere here, that the ECU uses. Best to completely disable it — there is no significant upside to using it.
Old Dec 16, 2025 | 10:02 AM
subterFUSE's Avatar
2018 S560
Experiments have been performed that showed Engine Start/Stop causes excessive wear to engines. Doesn't matter if the engine is warm or not, it still wears out faster. Best to disable it always if you care about engine longevity.
Old Dec 16, 2025 | 11:34 AM
S_W222's Avatar
Current/Last 5-years:GLS;G70;Alpina B8;X7;Accord. Sold:X7,TeslaS;S560;S550,X5;530e;L.Navigator;LS460
I've had that coded on my W222 in the past. Max from @EleBest , official forum sponsor, did it for me and he also eliminated the (4-cylinder) deactivation which is also a part of this eco mode while driving sometimes and cause tiny vibration.
Old Dec 16, 2025 | 10:34 PM
Donnymac's Avatar
63 Falcon vert
Would agree. Ninja’s menu of options is long. Look it over and reach out to him. Get it all done at once. Simple process with Ninja. Been there done that.
Old Dec 19, 2025 | 04:30 PM
SSBN629 Seattle's Avatar
Currently ‘2015 S550 4matic. Previously 03 E320, ‘06 S430, ‘08 S550 4matic
I’m dizzy from reading everything I can find about disabling the Eco Stop/start default to “on”
Who is Peter? What does it take for him to program my car to remember “last setting”.
I also have seen references to a module to plug into the car to reprogram the system.
They cost $200.
If someone out there has one they don’t need again, I would like to buy/rent it.
BTW…my S550 is 2015 4matic.
thanks for the help
Chuck
Old Dec 19, 2025 | 05:20 PM
C Swenson's Avatar
2015 S550 4Matic, 2014 ML550
Originally Posted by SSBN629 Seattle
Who is Peter?…
Peter is also known as @BenzNinja.
He has a banner ad at the top of the page.
Old Dec 19, 2025 | 05:31 PM
Thanks✌️
I thought that he might be BenzNinja but wanted to make sure.
Old Dec 19, 2025 | 06:29 PM
GTIBlack's Avatar
Mercedes SL R231
...If someone out there has one they don’t need again, I would like to buy/rent it.
Mid City Engineering makes the module. It is for a single car use. You cannot reuse on a different car. Put the money towards a BenzNinja Club lifetime membership. You will get so much more use out of it.
Old Dec 19, 2025 | 06:51 PM
thank you..that advice helps a lot.
I am looking into the BenzNinja program.
At my age (77) a lifetime membership to anything is almost laughable!
However, once I get things arranged, it sounds like a lot of fun to play with upgrades.
I appreciate your help
Chuck
Old Dec 19, 2025 | 11:11 PM
as.thompson's Avatar
Veteran: Air Force
S550C4, Porsche Cayenne
My Stop/Start seldom works regardless of temperature. I guess that it sort of deactivated itself. So I leave it that way rather than screwing with the myriad of input sensor.
Old Dec 20, 2025 | 09:38 AM
GTIBlack's Avatar
Mercedes SL R231
Chuck
Maybe you can put the membership in an estate trust. I’m sure BenzNinja will get a laugh out of it.
Old Dec 20, 2025 | 09:40 AM
GTIBlack's Avatar
Mercedes SL R231
One of my cars is like that. The problem is that it would start working when I didn’t expect it. I HATE Start/Stop! Both cars now have it permanently deactivated.
Old Dec 20, 2025 | 10:17 AM
W205C43PFL's Avatar
Kind of glad we don't have cylinder deactivation like the newer MB engines.
Old Dec 20, 2025 | 04:36 PM
badq45t's Avatar
2016 S550e, 2005 Nissan Xterra 4x4, 1984 300ZX
The S550e does this but totally smooth and engine shuts down as you coast or brake into a stop, and the electric motor brings the car off the line and it gently kicks in. This is the only car that I have not deactivated this (well rental cars at least where I literally Googled it as it was so annoying).
Benzninja was awesome, for sure you need to turn on the Intelligent Lighting System (ILS), which is the biggest upgrade I did with him (Google it total game changer for night driving), he also converted my gas gauge to gallons vs percentage, video/text while moving (not that great as my 16' still is not very good at text as you cannot use the excellent voice input), engine data (horsepower/torque/amps/oil temp) and lowered by 1". He also updated the maps which I don't use often.
Old Dec 20, 2025 | 05:22 PM
subterFUSE's Avatar
2018 S560
ILS+ is nice. Although, I also have a 2023 Audi S8 in my garage and enabled the Matrix headlights with highway light carpet. Now THAT is on a completely different level. The Audi lights are the best in the game these days.
Old Dec 21, 2025 | 06:47 PM
badq45t's Avatar
You cannot compare a 2023 to a 2015 model, I am sure MB did a lot of big improvements too...but if you have a W222 this upgrade is well worth it and I just cannot understand why USDOT will not let MB turn this on for you market. So many people I know are complaining about LED headlights and how bright they are, with ILS you don't have to worry about blinding people with low beams or high beams
Old Dec 30, 2025 | 09:36 PM
JohnnydoeyR230's Avatar
2004 SL55
On my w222 S65, I was able to use my Xtools D8 scanner to disable start/stop. It’s permanently off doing so and I imagine any decent scan tool or possibly Xentry could do this?
Old Dec 31, 2025 | 04:41 PM
JohnLane's Avatar
222 S-65
Most common reason for this is an iffy battery.
