Cylinder Deactivation Experience
Other than the freeway I would NEVER use auto stop/start (more like auto explode/engine), but I wonder how this cylinder deactivation could effect the engine long term. Should I not use it? Or is it totally fine? I plan to keep this car for a very long time, and put a lot of miles on it. So if not using this system means more time with the car, I'll take it. (you can tell me I'm stupid for using this system, its ok lol)
Any thoughts would be appreciated, Thanks!
OP Cylinder deactivation and stop start are only there due to our .Gov overlords insisting on it. Zero benefit for the car. There is so much more to life than a few more MPG.
I coded it off permantitialy with help from Max at @EleBest . It was also causing the car in-town to induce some harmonic minor vibration when the car is cruising and running on 4-cylinders only, although most people wouldn't notice it but I do.
Reminds me of the old Cadlillac Northestar engines that did it....and blew up during their short lives.
Engine Start/Stop has been shown to cause excessive wear to engine parts, reducing overall longevity of the engine. Experiments that tested the effect of many years worth of start/stops vs. the same engine without the feature showed significant differences in wear.
It stands to reason cylinder deactivation would do the same.
Cylinder deactivation.... Cylinders that are not running don't have cylinder pressure keeping rings well seated. Oil consumption will certainly follow in the long term. The Mechanical ish that goes along with making it run on less cylinders... They don't just cut injectors. Not worth it!
For the W222, this is true.
For newer cars like W223 or in my GLS X167, these cars have 48V that powers an electric integrated starter generator which is why it is less "clunky" with that started and it doesn't vibrate or cause as much as bearing issues with time.. it is more of an electric motor is sandwiched between the engine and transmission that can spin the engine up tp 800-1000 RPM almost immediately without "grinding" engagement as in the W222 or cars that don't have the electric 48V starter.
Both cylinder deactivation and auto start/stop do not really benefit the end user. They are for the benefit of the manufacturer as the drive cycles used during homologation are conducive to resulting in higher mpg numbers with those two "features". The cycles use grandmother style acceleration and have many idle phases. Often disconnected from the real world. Even WLTP, which is supposed to be closer to the real world. Jason on his Engineering Explained channel has a good segment on auto start/stop showing that it can save fuel if the engine is off for at least 7 seconds. If it's off for shorter duration, then the additional fuel injected during engine start more than offsets the fuel that was saved by turning the engine off, so engine start/stop can actually increase fuel consumption in the real world, rather than reducing it.
I tried once to have my dealer address the shudder when the 4-cylinder occurs as am cruising with very light acceleration, and they said it’s just not possible as it is a result of the V8 running only half of the engine so it’s unavoidable. Poor design. Coding it off was the only option I found.
If the engine was designed for start/stop, then using it is fine.
If not, then using it is NOT FINE.
For example, the amount of gas I can save with S/S is less than the replacement cost of a new starter--thereby, S/S is not cost beneficial to the V12 engines.
