Oil Cooler and Oil Filter Housing
Just completed this job:
R/R Oil cooler & gasket. Torqued to specs.
R/R Water Thermostat Housing & gasket. Torqued to specs.
R/R Upper Cam Covers resealed & new bolts
R/R New Actuators & Seals
R/R New Cam Sensors
R/R New Serpentine Belt
Installed Pigtails to Sensors & Actuators
R/R New Turbo Cooling Lines (driver side). Purchased 2 aftermarket Lines, cut away the plastic connector ends, used new rubber tubing to rebuild.
What a job!! Not for the faint of heart. Every bolt put back & tightened to specs.
Turned the key - Waalaa.
Thanks to all the Posts givning me insight & tips on getting the job done!
Many of us have replaced with silicone and had great luck.
