222.186 - S560 - 2018 - Front and Rear differential plug torque specs
Subscribe
Mar 3, 2026 | 11:33 PM
Can anyone confirm the torque specifications for the front and rear drain/fill plugs on a 2018 Mercedes S560 W222 4MATIC?
It would be great guys if a PDF can be shared from WIS
VIN "WDD2221861A379791"
Reply 0
Mar 4, 2026 | 08:36 AM
Oddly enough, this one-page WIS doc mentions but does not provide the torque spec ? With sealant on the plug as shown I'm sure it wouldn't need to be terribly tight
Reply 0
Mar 4, 2026 | 05:59 PM
Correct answer is as snug as you can get it without pain while pulling on a 12" spanner. Tapered threads on the fill plug generally. Where it uses a gasket same torque as used for an engine oil drain plug.... AKA less than so many apply. Just need to crush the drain plug gasket; not strip out the threads.
Reply 0
Mar 5, 2026 | 12:22 AM
Just snug it real good, not super tight, just real good.
Reply 0
Subscribe
Currently Active Users (1)
