Stiff suspension
Having said that. Z rated tires will be stiffer, and the lower the profile, the stiffer they are. Just one word of caution, if your roads are bad and you have a habit of driving through potholes, then the lower pressures will give you less protection.
Ultimately, if you want comfort oriented tires, you need to look at touring tires and larger sidewalls. Also, your tires are likely runflats as most cars these days don’t have a spare tire anymore. Those are also stiffer. Many replace them with non-runflats and carry a flat tire kit.
Edit… I have the tire you’re running on my Fcar and it rides fine. 32-33 psi.
the Pilot Sports are clearly the better performing tires when pushed but ride like they’re full of water compared to the Primacy’s.
Yesterday’s eighty mile drive had me thinking about Goodyear’s “Assurance Comfortdrive” tires.
The DWS is still a performance tire. If you want a comfortable, but still excellent dry handling AS tire, I recommend the CrossClimate2. It's available in OP's sizes and load rating. That's a Grand Touring AS tire and is actually rated for severe snow service, complete with the three mountain peaks. It's an all-weather tire, rather than just an AS tire. An AS tire without the three mountain peaks is still subject to chain control on an AWD/4WD vehicle. I've got it on my wife's car for an occasional trip up to Tahoe. Prior AS tires were crap in actual snow.
I use summer tires all year round here in the valley of the sun.
I like to run 32psi on all cars. The continental are by far the softer ride. But they are more noisy. I find that when I raise the 560 with the airmatic suspension it rides harder and doesn't handle as sharp. Definitely a softer ride with lowered suspension mode.
