I hate this digital dipstick
Waiting to the next day to check oil level again only to find the level is pinned above the MAX mark. Now I have a problem needing to put the car back up on the lift drain out some oil and check the level again. This could develop into a major PIA.
What am I doing wrong? What did I miss?
This may be enough to get you to normal. If not, remove the entire oil filter cartridge and replace. Much harder to control the volume of oil draining with removal of the main oil pan drain plug.
I typically find that it takes 9.0 quarts at most to fill my S560.
It will be easier next time!
